Floating Dock Dilemma
rgramjet
Hello,
I just built a floating dock for one of my clients. We replaced an existing one that went with the previous owners of the house.
My dilemma is this: the floating dock is attached to a rigid dock with 2-1/4" galvanized pipe. The pipe is sunk into the ground on one end. At the other, it comes to an elbow then is joined to the rigid dock with a bolted on flange. The Chesapeake Bay experiences considerable changes in tide. The other day, when the tide was high, I noticed the dock was up to the maximum height (where the 2-1/4" pipe attaches to the rigid dock joists with 90 degree elbows and flat mounting flanges). Over time I can see this putting considerable strain on both the rigid and floating docks. What has me worried is last year I visited the dock when the water was higher that the rigid dock!!
Any suggestions would be greatly appreciated!
How about removing the bolted on flange and weld a u-shape piece of steel to the floating dock - then place the u-shape connectors over the 2 1/4 galvanized pipe. That way if the tide exceeds the height of the rigid dock, the floating dock would contine to float up.
The floating dock has a 6" long x 3" diameter pipe welded to a flat piece of steel. This rides on the outside of the 2-1/4" pipe thats mounted to the rigid dock. I was thinking about mounting hinges on a pice of 2 x 8 so that the floating dock when at its max height can at least pivot without putting too much stress on the 2 x 8" bandboard.
I used to have the same set up, I set the pipe 2.5' above the bulkhead height to allow for flood tides and then used 2-90 elbows pieced with aditional threaded pipe and flanged to the top of the bulkhead -creating an upside down 'U'.
The flange is actually a 1/2 of a union, 1 union will give you 2 flanges
Brilliant! Ill make the pipe rise high enough to where it could be used as a handrail to step onto the floating dock! Thanks so much for the insight and inspiration!
