Fluid Leak at Helm
dwarren
A friend of mine just started seeing fluid leaking around his fly bridge helm. Can't seem to see leaking from fittings or hoses. He did notice a vent at or around what I think is the bezel area. I'm not too familiar with his set up as he said when he adds fluid in the reservoir in the bilge, he has to pump it up to 21 psi or something to that affect. Currently, he sees that the pressure is still there but there's no fluid in the site glass. My first thought is air pocket and in this heat, expanded and blew fluid out the vent but just not sure......Odd none the less. The helm is only two years old BTW...... It's a mid to late 80's 37 Silverton Convertible. Clean as the day is long by the way....
Any ideas?
A 1980s era Silverton might very well have Hynautic hydraulic steering. I know mine does. The helm pump does wear and the result is the leak that your friend has seen. No amount of refilling and pressurizing will stop the leak and if left long enough, the helm will stop responding entirely. Hynautic was taken over by Teleflex years ago. I had mine rebuilt at boaterstore.com. Fast and not at all expensive.
You say that the helm is only two years old, so perhaps it isn't a Hynautic. Two years isn't much for a helm so maybe there is something else going on here.
If he has no fluid in the sight glass, I m not sure how his steering could even work
Indeed with most Hynautics you add fluid to the reservoir down below and then pump it up with an air pump to 20 psi or so to push fluid up to the upper helm.
Leak could be one of the hose/connector or the helm itself, which is really just a hand crank pump. I the leak is small he can just top it off but eventually it will have to be rebuild.
It's a sea star helm manufactured by teleflex in canada. Leaking out fill cap on top.....
On the SeaStar the uppermost helm's fill plug is vented to purge air but it also has an O-ring at the top of threads. He might check that o-ring in case that's missing or broken , but there might be something else amiss in the helm pushing hyd. fluid out that way. It doesn't make sense to me that enough fluid should make it's way out the upper helm purge plug to leave the lower pressurized reservoir sight glass empty unless there is a lower leak.
For that matter & FWIW, I ...thought... only the Hynautic systems had the pressurized reservoir & sight glass but I certainly could be wrong about that. Have any parts been replaced recently and possibly mismatched for the system ?
http://www.jamestowndistributors.com/userportal/pdfs/Teleflex/TMTechCat-HydrStrg(v4_0)Parts.pdf
my 85 37 silv has the hynautic system I did seal repair and it stopped leaking it has the pressurized reservoir & sight glass I think it is the h 50 model helm
Our Seastar helm started leaking out the front last fall. We installed a new seal that Teleflex sent us; problem solved. Call Marc at 604-248-3858. He posts quite a bit on thehulltruth.
