Flush Deck and Dogs
Max_L
We ended up buying an Express cruiser over several flush decks, Chris Crafts, Hatteras, Matthews, Bertram's, because we didn't want to fight getting our 100 lb lab off the back. We have him trained to swim ashore to do his business then come back and walk up his doggy ladder and wait to be dried off.
Yet, I always wondered about a Boarding gangway (stairs) down to a dinghy? I use to work on Captain and Admiral Gigs in the Navy and we would pull them up alongside a gangway for officers and dignitaries to board off or on.
On some of the flush decks we looked at they had the a midship boarding stairs. Would those have been strong enough or have a side support to the hull that would have allowed our dog up and down? I have seen some spiral boarding steps to the swim platform on a couple of 53 Hatteras but it takes away from one side or the other for boarding from a low floating dock.
Just curious....
A friend has a Chesapeake and they're both showing their age. She got a heavy duty plastic 'telescoping' ramp. It's a good 4' retracted and extends to about 6-7 feet. It's for her truck so it's too short for a boat...but there might be something out there for boats.
A friend has one (Doggy ramp) and they work when you have the room to extend them. I was wondering more about the stairs that come off a side platform and go down to about water level. Some have wheels and they roll on the dock as the boat shifts or moves. I thought that might work when the boat is on the hook and one could bring their dinghy up to it.
Here's a couple of Pics I found. I just wondered how well they work. Seems like they are a little high off the water. The other pictures are one's that I have collected to get some ideas of how to make or have one made for a Flush Deck.
http://i31.tinypic.com/14njrlz.jpg
http://i32.tinypic.com/2r4hi0p.jpg
http://i26.tinypic.com/33p81w1.jpg
http://i25.tinypic.com/9a5t7p.jpg
http://i30.tinypic.com/5mzhi.jpg
http://i32.tinypic.com/f10gfc.jpg
Here i$ what big yacht$ u$e to board people from tender$:
http://www.marquipt.com/products/31.html
I'd imagine any dog that can get up on a swim platform could get up on one of these, but I'd sure want to know that before I bought one!
We have the kind of stairs you picture, that roll on casters on the dock. A big dog shouldn't have a problem getting up them, but ours are not designed or easily adapted (that I can see) to use on water. They are a PITA to set up and take down, and we only use them if we are going to be at the same place for awhile; otherwise we use a ladder that clips on. Sailorman in Ft. Lauderdale usually has a variety of used stairs in the back yard, sometimes including the on-the-water kind.
George
Hatteras 56MY
they are a PITA! heavy but well built, so i guess weight is the price we pay...
I use mine as a ladder, with a fender behind, since my finger pier is too short. We climb down 2 or 3 steps depending on the tide and then step on teh end of the finger pier. you could do the same to get down to the tender, but not dogs, obviously.
i've been looking at other solutions, incl. doing another cut out in the railing and life line 10' further up and adding the fittings there so that i could use teh stairs. Or adding a couple of tubes at the bottom , where the casters are, to force the stairs from the hull. not sure how that's going to work... or plan C, supporting the tip of the stairs with cables, attached to teh flybridge with a short boom to get the right angle.
major PITA, just because marinas never build finger piers that are long enough!
The Marquipt is similar to what we had on our ship (Navy's not ours). Then again there was about 10, 18 to 19 year olds to set it up.
I think before I would pay that amount of money I would have a custom stair mold made for the transom. Something like this, I think it was done on a Hatteras.
http://i30.tinypic.com/1678h28.jpg
I think that Marquipt cost more then our boat...then again a mold could be very costly too. How about a basket (like CG uses) for the dinghy hoist and lower the dogs down.
Better yet, I think our next boat will be a Yachtfish and that will settle it all.
Sure do a lot for our 4 legged family members.
i've actually used my dinghy crane to lower a 120lbs bulldog from the aft deck to the dinghy, using a PFD as a harness... it worked, but really not practical.
if you have dogs, a YF is a must. Even those transom stairs are pretty steep for large dogs.
of you could setup the marquipt at the stern, from one corner down to the platform, along side the stern, using one of the extension they have.... not very stylish but cheaper than redoing the whole transom.
I think stairs are just too bulky to deploy/retrieve. I've always made or modified existing designs. I was thinking along the lines of an extension ladder. The kind with ropes to extend them. You can collapse them upward and extend down. When retracted up, fold up and tie to the railing. 1/4" ply pop rivited or cable tied to the rungs as the ramp and non skid paint.
yes they are but they make it so much easier to get on and off the boat that they are worth it. Ladders just dont' compare...
My ladder is pretty darn simple. Put in bracket, snap in two pins and you're good. Stows on the gunnel on a couple of pin mounts.
We looked into putting a spiral staircase or similar on our boat when we bought it, along with a wider and deeper swim platform. Not for a dog's use (ours was very portable), but for less fit guests. After using the boat for awhile, we said the heck with it and the many B.O.A.T. units involved. We gave the dog to one of the kids after he fell down an open hatch during the survey. Good move on our part. I see what people go through to accommodate their dogs when cruising, and it's really like they are a professional captain and crew and the dog is the client around whom everything revolves.
George
Hatteras 56MY
When you have an Admiral that was in Veterinary medicine, you will always have 4 legged family members. We had 5 cats at one time but none of them ever made it to the boats.
120lb Bulldog, that is huge, we had one when I was a kid but I don't think she weighed over 50lbs.
