- Aug 17, 2004
- 14904
- 493
Last year I almost lost my Trophy when it was tied to a can in Capitola Harbor. It developed a leak and almost sank before Ed, Mike and the guys from Capitola Boat and Bait came to the rescue with auxillary pumps. A lot of you gave me good advice on how to clean the mess up and it has finally all worked out. The water was so deep in the cockpit that it came over the engine's dipstick and we had water in the bottom of the crankcase. It turned out that the leak came from one of our self bailing scuppers that drain water from the deck out through the transom. That pipe cracked at the elbow as it made a ninety degree turn upwards to the deck so now the water just came in as the break was even with the water but below the height of the deck. We fixed that and now we are totally dry. The boatshop drained my engine of all oil, replaced the filter and started it up for a minute or so, then drained it again. They did this about four times and there is no trace of water in the engine. I ran it hard up around Franks Tract a couple weeks ago and the oil on the stick was crystal clear, no milkiness or discolorizion. The whole repair including starter, alternator, belts, power steering pump etc was a couple thousand dollars but I think we're home free. However, I think a hear a little noise coming from the gimble bearing........ Thanks again to all who offered up good advice.
DBH
DBH
