Forward Hatch NO LONGER Leaks!
The last time I washed the boat, I discovered the leak eventhough the hatch was completely closed and locked. Of course with a 15 yr old boat, this happening is not surprising.
How do I fix this? Do I just put a bunch of silicon were the water comes in or should I replace the gasket? Any other ideas or thoughts?
BTW---this is not a Bomar hatch. It was mfg in England. I'll have to look for a brand this next weekend.
Liz:
I had the same problem last year and found that my gasket/seal had come loose in the corners..My seal was a rubber one....Is yours the same?...Check to make sure that it is glued in place..I reglued mine and had no more problems.
Liz,
are your hatch handles adjustable for closing pressure?
Liz, my Bomars would leak slightly after a hard driving rain or if I aimed water at hatch while washing. There were no tension adjustments on my handles so I put a wooden tongue depressor beween handle & frame where handle locked. That forced more downward pressure on hatch & stopped leak. Got tired of that & spoke to Bomar. Didn't make sense but they told me to replace the original "O" rings in handles. Got some at hdwr store & no more leaks; go figure. You would think that would work against me as that would push handle farther away from frame. Oh well, it worked !
Take a close look around the gasket, where it meets the frame. As Carver mentioned, make sure you don't have gaps in the corners. I found with mine that the best thing was to remove the gasket (Carefully!), clean all old glue/sealer off the gasket and frame as good as possible, and then reapply and re-seal the gasket. I re-seated my gasket and then little by little lifted the gasket and applied silicone. If you try to put silicone on the gasket or frame first you'll have a mess! I then closed the hatch to put even pressure on the seal and let the silicone dry. Also, if your gasket has a seam, I think I put the seam at the bottom. Sounds counter intuitive, but it allows the water to run around and away from the seam rather than pool on the seam and run in. DO NOT just put a bunch of silicone on leaks as you alluded to in your question - more is not always better.
Sorry, a little long winded, but when it comes to leaks you're much better off taking a little time and doing it right.
Originally posted by Flutterby
Yes, the seal is rubber. What did you use for glue.
Thanks!
went to the local automotive parts store and bought some glue for regluing the weatherstriping on car doors..Worked like a charm....
Very good information here. I have a slight leak around the gasket and if the gasket seals just right I have a few drops from one of the handles. I guess I will replace the "O" ring in both handles and see what happens. Thanks Bunch
Thanks for the info Bob.. never thought the handles would have o-rings...
Can you tell if the leak is between the frame and deck OR hatch and frame? If you're not sure or can't tell you'd be better off removing the whole thing and reseal the frame to the deck and then hatch to frame. If you can't get a new gasket you can use silicone. You have to clean the old sealant from the deck and maybe sand it to make sure.(same if there's sealant on frame) lay a bead of silicone on the deck and a smear on the frame and place the frame down on the opening, gently settle the frame on the silicone bead. Put a couple of screws/bolts in the frame to keep alignment but don't tighten down until the silicone has set. Reseal each screw/bolt.
Wow! Lots of things to look for and consider. Thanks for the input! I'm going to print out this thread and take to the boat with me. I'll report back what I find and probably have more questions. You guys rock!
[I should post my question on the Women Only Forum and see what I get......NOT]
Also look for a split in the gasket, sometimes they are made with a joint and shrink over time opening the joint. Start with a good cleaning of all surfaces even under the gasket if it removes easily. If there is a split you can add a bit of white silicone to the split and smooth out with a wet finger. Let dry overnight if possible or the hatch will stick closed.
This hatch is NOT a Bomar. The mfg was in England. Since the hatch is 15 yrs old, I don't know if they are still in business. I'll let you know. And the frame/gasket is black.
Liz, definitely DO NOT just put more silicone around the hatch. If the leak is there, the only real way to fix it is to remove the entire hatch and re-bed and re-seal it.
It is a time consuming job, you have to cut through the old sealant, then loosen the hatch, remove all the mounting hardware and force it out. Make sure you clean the entire surface of all the old silicone/caulking/sealant. When you re-bed, do it according to instructions, that is, put a bead around it and let it set for a while, or else you will force it all out when you tighten the screws.
In one of the recent boating magazines there was an entire article about doing this job. If I can find it, I'll let you know which one.
I have to do the same thing this spring.
Hogan, now that you bring it up, I remember that article too. I'm pretty sure it was in BoatUS magazine.
Didnt read carefully enough. [:() if there is any brand name try searching. In my experience the first amd most likly leak location is the gasket not the mounting. Some have adjustments for pulling tighter.
Liz: the way to test the gasket is to use a strip of paper about an inch or so wide and close the hatch on it. If the hatch is sealing there will be some friction as you pull it through. No friction means you found the leak.
hate to be a killjoy here but, if it's leaking around the deck seal--chances are good that you have a saturated hull core...that will need to be dried and glassed/epoxied up before replacing the hatch.
drying can take months.......it did on mine.
[:-cry]
