Fresh & Waste Water Gauge accuracy
Originally posted by rommer
Both of our Regals have had terrible luck with the waste tank sensor. Cleaning them would make them work for a while but it was a VERY nasty job to do. I switched to the Snake River gauge system which uses two metal strips mounted on the outside of the waste tank and I could not be happier. Accurate and they ALWAYS work.
John, which model did you get and where did you buy it. The waste and water gauge on my boat was useless from day 1.
Hi all,
A couple of months ago, I replaced my old style Fireboy tank monitor senders and gauge with the new style, pressure-based units. It was relatively plug-and-play (the new senders use fewer wires than the old ones) and it seems to work much better now. Just FYI.
-Brian
2001 Regal 2960
"Full Circle"
My guages seem accurate. I can see my waste tank and guage is a accurate reflection. Fresh water also is accurate but then again both mine are fairly new. My waste and water share same guage on panel.
This is not a "Regal Problem", but seems to be an industry problem. Silverton pretty much gave me the cold shoulder when I addressed this with them while my boat was less than 3 months old. I can easily view my tanks so I did not break balls about this. I should have though.
