My fresh water connection is in a bit of a tight spot. I've been using the home depot quick connect which works ok, but, it's not durable enough for the amount of use I put on it. It eventually leaks badly, like now, and needs to be replaced.
Does anyone have a recommendation for a marine-grade quick connect system? I really only need the one connection (hose to boat) but if it works well I would use it for other areas.
