Fresh water tank...
aholst1
...do you leave yours full, empty, or somewhere in between???
For day cruising, I don't need to carry the extra weight of 35 - 40 gallons of fresh water, but I am concerned of the biology lab an empty tank provides. I do use the tablet style "purifiers" Feedback needed!!!
AJ
Our tank is more-or-less on the centerline, just fwd of the ER bulkhead. The 800 lbs of ballast it provides comes in handy in heavy seas. In calm stuff though, I'd rather not haul the extra weight. I'll fill it this wkd because we'll be spending time on an island with a history of drinking-water safety issues.
I try to cycle water through the system on a regular basis. I think keeping it fresh by using it is better than hoping a full tank doesn't grow anything, or by adding posison "for our health".
I shock the system periodically, then rinse thoroughly.
if you regularly use the boat i think you're better off keeping the tank full... that's what i've always dont even before living aboard.
i've never done anything to my tanks or water. fill up using city water which already contains chlorine, even drink it straight out of the 37 year old fiberglass tanks ! no problem.
Pascal, we use the boat every weekend, but even with additives, we do not drink. The water at each slip is lake water. (Gas dock has potable, city water)
The extra water weight simply causes a longer time to get on plane...
SLW, fortunately my tank is centerline also, under the bunk in the mid cabin, but boating on the TN River doesn't usually involve the term "heavy seas"
Fortunately, I was a believer in filtering the water that goes into the city-water hook-up and the tank BEFORE this happened:
This is my WHITE CERAMIC filter element, the day after the great "Algae Bloom of 2006"
You can imagine the water that created this slime. Had I pumped 100 gallons of this crap into the tank, it'd probably be there forever.
If you don't need the water for ballast, or as a supply while boating, I don't see the point in carrying the extra weight in a planing vessel.
I am a victim of that island's bad water, but I'm still going to wait to fill it until I get there.
I am hoping after all of their problems and the scrutiny they got over it, that they have that all worked out.
Besides, I do believe if you drink enough alcohol it will cleanse anything you might catch, or at the very least, make you not care as much.
Perhaps you should consider consuming alcohol for a change to protect yourself from those water problems, SLW.
what? and give up TEA? [:O]
Although it is a good idea to filter city water--be sure and add chlorox to the tank/water afterward. You remove any chlorine when you use a charcoal filter. We tend to empty the tank if it will be more than a week or so. Living aboard and cruisng we kept the tanks as full as possiable. We shock the tanks with chlorox every 6 months.
We tend to keep our watertank (bladder actually) empty unless we know we're going to be out overnight or for longer periods. When I know I'm going to leave it empty I pour a small cup full of clorox bleach into it and rince it completely a couple of times before we refill. We also don't drink this water only use it for dishes and washing up etc. We carry a Coleman insulated waterjug for drinking. Only practical on a small boat though. Guess it depends on the quality of your water supply. We just got nailed with a $4K bill for our new water filtration plant with state of the art activated carbon filtration system so I'm guess our tap water will be potable!
If you turn the water over and don't let it sit, there should be no problem so long as your system has been sanitized. We refill at least weekly with fresh city water (average 1/8the tank), dump it (purge) using all outlets at the same time and refill monthly, sanitize it every six months using Clorox solution (1/4 cup plain Clorox per 15 gal capacity, top with fresh water, soak 3 hrs, drain through all outlets, refill, soak 1 hour, flush, refill and go).
I used to run 5 micron sediment filters on my old house - after three months they would look just like the photo SLW posted. Most of what is collected is iron oxide and silica. If the filter wasn't there you would never know.
Bob, clorox/chlorine is the "poison" I referred to earlier. I'm not keen on the idea of ingesting it.
As for quality of city water, I agree - some is better than others, but I had no indication or warning that ours was going to turn into sludge when it did. I'm just REAL glad that I had that filter. Without testing and investigation, who knows what could be coming out of those pipes? I'd rather invest in a filter that I can take with me and count on then lab results that I have to pay and wait for, and may only represent the water quality in a given window of time.
Again, as far as planing boats, if it's not needed for ballast or house-usage, WHY carry extra weight?
Eric, I was typing while you posted that, but I agree completely. BTW, the filter in the above pic went from clean, white ceramic to what you see there in a SINGLE DAY!
I totally agree, why carry the extra weight?
I like having a little bit of water just for washing my hands while underway, but not much.
I dont' get this carrying extra weight thing... 50gal is the weight of a couple of adults, isnt' comfort is worth an extra $3/hr in fuel
obviously it depends where you are and how you're using the boat... in salt water and where it's hot, or if you spend the whole day ... you're going to need water on board.
has it been that long ago since you've been on a planing boat Pascal? If the weight of a couple of adults is the difference between planing-out easily, and struggling, then it's not "comfortable" or sensible to carry it.
