Fridays Seatrial
jacko
It went well. Only thing that did not work out was the Genny would not start. They are replacing the fuel pump and hopefully it will be running tomorrow. Also Have you ever heard of E2CY? The front wraparound is made out of this.
Glad to hear things went well I hope they correct the genny quick for you as for the front wrap are you sure it is not EZ2CY?
http://www.ez2cy.com/index.html
You should read some of the info on there site looks like great stuff but can't be rolled or bent like Isinglass.
It is EZ2CY ........ my Typo.
I don't know if i really like this stuff as it is so large and bulky and going to be a pain to store it. The Middle section in the front is missing ....... So I have a guy working on pricing that.
EZ2CY is expensive stuff.
Yes it is a hard material and can't be rolled but must be pinned up. However it is very durable and scratches can be polished out.
much better than vinyl IMO but any polycarbonate ( Lexan) works very well too.
EZ2CY is probably the best stuff on the market for enclosures. You will find that you will be replacing the vinyl side curtains before the front panels.
never been clear to me why that is better than coated polycarbonate, more expensive sure.
Call Gioia Sails for thereplacement you need. They made the original enclosure for that boat. They have the patterns and do great work.
I have big panels of EZ2CY across the aft deck of my boat. Fantastic visual clarity. We have the center panel set up so the we can fold it up and fasten it to the aft deck ceiling; very simple. It does flex, not a lot, but it does. You have to maintain it with 210 products by Sumner Laboratories. I can't imagine having anything else. Lexan is stiffer and heavier in my experience.
Nice boat! I didn't see any fishing lines out but I'm sure that fishing was part of the trial. Really nice pics.
I have coated poly on my boat, the main difference my canvas guy says is that with EZ2CY you can actually wet sand scratches out and buff it back without compromising the panel where with the coated poly you would remove the coating and the scratch or repair would age faster than the rest of the panel.
Spend your money how you want but after 3 years I have no scratches. since it doesn’t roll up they are less likely. Poly comes in several thicknesses and with 30 mil it can be bent around corners avoiding a corner frame. Notice the corners without any frames in the above pix. The bend makes it rigid. 50 mil is needed on flat panels for rigidity.
Mike, if your down this way I might be docking at Kent Island or Cambridge for a week or so while the electronics get installed. Might have to meet up for a cocktail.
That might happen. Will you be berthed on the Potomac?
Mid-shore in Camb. does a very good job on elect. installs. Martek in the Narrows did ours, and also a fine job.
Spring just can't come quick enough.
My EZ2CY was done by Lighthouse Canvas in Middle River, MD by the way. When we screwed up and cracked a panel, they re-installed a new one at a very reasonable price. Their quality is top notch. On the electronics, Mid Shore actually has their own dock in Cambridge.
Got a price on the EZ2CY
Fell over dead.
