- Sep 16, 2003
- 12212
- 12,221
my current fridge, a 18cu GE fridge/freezer, is working fine but being older (10+ years i assume)... it's only a matter of time.
i was also looking at the amount of power it uses, especially since we run on inverter a lot.
the energy guide label says 700KW a year, which i assume is an average based on Tstat setting, room temperature, etc... so that amounts to about jsut under 2kw per day, rb2@gr5t 120 v, 16amps. converted at 12v with inverter loss i'm looking at about 220/240 amp hours a day from the inverter bank .
i was looking around on the web and saw an 18cuft kenmore listed at 400KW a year. By the same quick calculation, that woudl drop my draw on the inverter bank by 40%...
two questions... does my math make sense ?
can you compare today's energy guide label to those from 10+ years ago or have they changed the calculations over the years ?
