Floscans range from $500-2,000 per engine (diesels and FI engines require two systems) depending on which series instrument you desire. The basic 6500 at street price of about $500 ($1k for twin diesels) will tell you everything you need to know. The pay back varies on how well your boat was set up by the factory, or what condition it is currently in. The installation of my Floscan quickly showed that my props were not correctly pitched and that my fuel burn was high due to the overload on the engines. I knocked fuel consumption down by a total of six GPH (3 per engine) after getting the props tuned properly and finding the right engine speed. More importantly, it added life to my engines by doing so. Overloading gas engines is stressful and inefficient but downright death for diesels. I was also surprised to find that my efficiency (mpg) increased at a slightly higher cruising speed than what I had been running. The payback for my system was in the first year. That was six years ago and probably around 8,000 gallons of fuel burned. At an efficiency gain of 6 gph, which equates to over 20%, at an average fuel cost over the past six years, that’s about $3k in reduced fuel consumption. Not a bad return on a $500 investment for my Twinscan.
