Fuel Flow Meter Owners...Need Feedback
Msibley
Moderator
I replaced my stock fuel gauge with a Navman F2100 fuel flow meter and I have a couple of questions.
I plumbed it before the fuel/water seperator filter and put an in-line filter between the tank and the meter as per instructions.
I idled the boat on the muff for about 10-15 minutes and have a 2.9 -3.0 gph consumption rate...sound about right?
Since I've now taken the float in the tank out of the equation, I'm assuming that I have to keep track of my gallons when I fill and set the meter to match the amount...correct?
What else should I know?
TIA
I don't think you should have put the meter BEFORE the fuel filter/separator, rather, after the filter before it gets to the engine.
Mine is running 1.9 - 2gph at idle on a 1986 evinrude 225hp.
Also did you make sure the meter is situated vertically?
Mike, you are correct in the location. In line filter before the sensor and sensor before the engine mounted fuel water sep.
You should be able to set the tank size so that the gauge reads currectly and so when you fill the tank you just enter full rather then having to enter the amount you added. It's a great reference tool, mine with twin engines was within 2 to 3 gallons when filling.
Mike,
Have you calibrated the unit? If not, you need to.
you also need to set the tank size, number of engines, and i believe the time you want it to take to get readings. I have mine set for around 30 sec. or so. You don;t want the readings constantly changing.
My book is in the boat, and not available right now, but the best advise is to do exactly what it says in the instructions.
Make sure transducer is mounted vertically. very important. good luck.
How did this post get new life when it appears it was 1st posted in 2006? Am I missing something here?
Geeze, it took three years for sib to get an answer to his post!
Mike's one of those Professors that put students to sleep. That's why they have Bells between classes.
I put an aftermarked system similar to Mike's on my 82 Escort and drove it from Ohio to Alaska. I think it was great. It's only drawback was that I had to tell it when I filled the tank, or if I only put 5 gals in. The newer Automobiles have the float in the tank integrated with the old Button the Humanoids had to push.
The one on the Escort and my Wife's Chrysler is accurate to the small parts of a gallon.
Remember, if you have twins and put the meters on both supply lines....a man with two clocks dont really know what time it is! So if your engines come up with a different usage, is it the guage system or the engine? And which one is correct?
I guess the old saying "better late than never" would apply.[:-boggled]
Ken
My Navman 2100 reds less than one gph, at idle, in gear, on a five liter, injected Mercruiser. Three gph is kinda large.
My port engine reads 1.9gal/hr and my starboard reads 2.6gal/hr at idle. I have twin Volvo 5.7's
I looked again, yesterday, and saw numbers like 0.4 to 0.6 idling in gear. Maybe its the fuel injection.
