Originally posted by pocket change
My boat has a 25 gallon tank and I get 3&1/2 mpg. I put my GPS trip odometer back to zero when I fuel up. When the trip odometer shows around 50 miles I will take 14 or 15 gallons. That to me is a more accurate way to keep track of my remaining fuel supply than reading the gauge.
That's good as long as you tend to average the same type of usage(RPM), as 50 mi at cruise will use a considerably different # of gallons than 50 at under hull speed ( trollers , sight seers) or near WOT.
But of course I'm just jealous you average ~3 x the distance on a gallon of gas as my boat.
Fish Guts- Even with a FloScan system it pays to have a decent gauge & sender. If for any reason the tank is not fully filled at gas-up or F/S totalizer is not reset to 0 at that time, the "Gallons Used" displayed will be way off.
A vertical sender such as the calibratable Centroid Products (no moving parts) sender , or vertical float-type like WEMA can both be much more useful than typical scheap swing-arm types, though Rochester Gauge makes a pretty good mechanical swing-arm sender and optional electric conversion module to send to the gauge.
No matter which kind of sender it's important that it is of the correct length for your particular tank depth and that it sends level from that Min. Usable level to top/full.
And CruzPro makes a fuel gauge that can "learn the tank shape" and compensate for the change in rate of drop at different levels.
Bruce makes an excellent point though, nearly any properly working sender and gauge can be used to surprisingly accurately assess gallons used or remaining if... you diagram the gauge needle position in a log book just before
full filling the tank, then record the pumped gallons at that particular needle position each time you fill until you have a really good representation of what your gauge is
really telling you when boat is at rest. If you add more register marks on the bezel or lens with tape or fine M/M that will help with accurate diagramming.
