Fuel Level via stick
David M
Time to start thinking about winterizing. I posted about erratic fuel gauges a while back. Does anyone know if the 1999 Sea Ray 330 Sundancer has a straight shot from the fill port to the tanks? I want to dip the tanks and stabilize them but I don't know which gauge is correct. The port reads 1/2 and the starboard reads 1/4. I don't want to "over-stabilize" them if there is such a thing.
TIA.
I'm saving up for flow gauges.
you shouydl be able to look at the hose routing from the filler to the tank, but i've never seen a hose going straight down as the filler is almost never straight above the tank.
can you pull the gauge sender and stick the tank from that opening?
1/4 tank is a pretty large difference, you dont' have any idea of what's really in the tank based on your log or the last time you put fuel in? that difference alone is evidence that you shodlnt' rely on the gauges but actual flow estimates instead.
FWIW,every stabilizer bottle I've ever read said that "over stabilizing" is not a problem. So other than waisting a little money, I don't think it's a big deal.
best solution is to pump the gas into your car and use it, in the spring put fresh fuel into the boat.
I used to have a 1971 wood, 37' Egg Harbor. The last year they made that model in wood.
It came from the boat yard with a measuring stick for the fuel tank with gallons marked on the stick.
that's what i do on my boat! i dont' even have electric gauges and dont' want them... i just lift a hatch in the companionway down below, unscrew the manual gauge and put a stick in. over the years i have it calibrated, it's bullet proof. although i always keep track of fuel used. even here on Charmer with good electric gauges, sight gauges on the tanks, and electronic totalizer on the engine ECUs, i write each run in the log with fuel used for the mains and gensets. I use the engine totalizers but double check that with the time run and speeds... i'm usually within 5% when i fill up the boat.
Agree that it is bullet proof. I just thought it interesting that my stick was provided by Egg Harbor and it's use was even spelled out in the owner's manual.
Do you have access to the tanks and can you rap on them and tell from the sound?
Are you worried about over or under stabilization? Over is not a problem. I routinely double the rec amount when I winterize.
I would go with the reading on the port tank since it reads more, and add Sta Bil accordingly. I've never had luck with boat fuel gauges being accurate, but I can probably tell you, within 10% or so, how much I have left in my tanks at any given time.
Adding a little more Sta Bil than is needed isn't going to hurt anything.
KiDa,
Treat your fuel by the size of the fuel tank, not the amount of fuel on board!
Absolute,
"Suckin Sludge & Havin a Gas"
Yes I do. I shall try that. Additionally, it will give me info as to which tank is reading correctly.
Thank you.
Originally posted by absolute
KiDa,
Absolute,
If I understand you correctly, I should stabilize to ~110 gallons per side (109P/112S) and be done with it. That would be easy and a very inexpensive fail safe.
I'd go along with the above, treat the tank, not the fuel on board. It's easy and quick and the couple extra $$ could save you much more later.
As far as sticking the tanks is concerned, just try it. I'm sure you have a swab or broom somewhere on that boat.
If the handle looks like it goes to the bottom of the tank you're good to go. I stick my tanks every time I take fuel... the rest of the time I use the fuel gauge (whose error has been determined by sticking the tanks).
IMO that's the ONLY way... though a lot of boatbuilders will disagree with me.
The purpose of treating the fuel is really to address the condensation; the demon that creates the algae in diesel and promotes Phase Separation in ethanol blends. Condensation is generated in the dead air space in the tank, not the fuel.
Keep in mind, some fuel treatments recommend that you double the dose for long lay up periods.
Absolute,
Stabil or Way too much Stabil is what brought me to George's site. Way back in time, I got a motor off a guy. He'd put too much Stabil in the tank and ran the motor till it Chugged to death, smoking etc.
I went to the internet for help and found George's old site. Cant remember the name of it now.
George asked me to send him the Carb. I declined. I didnt know who he was at the time, but now I'd send him whatever he'd ask for.
What I found was the Stabil caused the Rubber "Point" on the Needle valve to "Puff up" so when I ran the motor out of gas at the end of each trip, the needle would stick in the Valve port.
Every time I went to start that thing I'd have to take the Hose off and blow hard on the Fuel line to force the Needle out of the Seat.
Then it'd be OK as long as it was running.
That was my first and only Stabil event. I do not believe Stabil helps anything!
I used Stabil every November and kept my tank topped off all winter long for 19 yrs. Never had a fuel problem for 19 yrs. This was a Merc 4.3L, not an OB.
KiDa,
Absolute,
If you fill them, that will certainly work. You can't "stabilize" old fuel anyway so calculate the amount of stabilizer needed, add it to each tank, and fill them. Run the engine(s) long enough to get stabilized fuel throughout the system.
The best plan is to add stabilizer each time you add fuel all year long. That way, it's stabilized already and ready for any extended layup.
A friend of mine uses the stick method. He's never been very fond
of "those darn electrical gadgets" (his quote) even though he's a retired
electrical engineer.
Well to make a long story short he had engine problems very often
right until the engines just quit.
The obvious question was made; "Got gas??" "Sure" He said as the
famous stick was lowered into the tank. "See? It's full" We where puzzled with his
predicament until I smelled the dreaded stick.
Wouldn't you know. The stick showed full alright, but full of water, not
fuel... :-)
