Fuel line and anti-siphon valve question
Sea Bitt
Fuel line questions. I have a 20-year-old Carver 28 with twin crusaders 220. I'm in the process of replacing the fuel lines and valves due to age. I'm not sure where the anti-siphons valves should be placed. The configuration is two tanks, twin engines, and two three ways valves so either engine can run from either tank or both from either one. One problem I have seems the gas line drains after a day or two and takes forever to get the engines started. If re start the same day no problems. Not sure if that is an anti-siphons value problem or not. Thanks for the help.
