Fuel top off?
Ehoyles
Since the price of diesel has dropped considerabley and will probably continue to drop well into the spring, what is the opinion of the members about leaving the tanks 1/4 full and waiting until spring.
Additionally, would covering the vents prevent condensation in the tanks?
I've seen people cover the fuel vents, but I think that's a really bad idea. If they're covered, they can't do what they are supposed to do. Probably not as big a deal with diesel though as it is with gas.
There seem to be as many arguments for leaving empty vs. leaving full. I know in the gas world, volvo recommends empty and mercruiser recommends full. So without a mythbusters episode, I'm not sure there's a right answer from a science standpoint. And both approaches seem to work out fine come spring.
But from an economic perspective it's another story. Like playing in the futures market. Will it be cheaper now or in the spring when you go for the first fill-up. I go empty in the fall and fill in the spring. Each year for the past 3 I've been burned with higher prices in the spring then in the Fall. It seems like with summer driving season coming, prices start heading up. I may need to start hedging my fuel position each fall like Southwest Airlines!
I just filled up for the winter w/ 72 gallons. Prices at the dock aren't coming down as fast as on the street: it's $2.89 (87 octane) vs. $4.15 (93 octane) at the dock.
Gas should be empty or drained. If left in tank (no fill up needed) & stablized.
Diesel should be full topped off & stablized or Startron (I use it)
Difference is Diesel will attract moisture Gas will not.
I think predicting diesel prices continuing to fall into next spring is pretty much a gamble, as soon as the economy shows any signs of rebounding the first commodity to shoot back up will be oil.
Here we go.
I can't comment on the diesel part, but that's not correct about gas. The ethanol in current gas blends is a terrific moisture attractant. It will bind with moisture in the air and, in extreme cases, settle out to the bottom of a tank in a "phase separation".
From what I've read on the subject, you should do one of two things for gas: either fill it up or leave it empty. There are arguments for both. Don't leave it half full.
Here's why. Air enters the tank via the tank vent. Over the winter months a warm day will heat up the air in a fuel tank. As the air cools any moisture in it will condense on the exposed tank surfaces (cooler air holds less moisture). The water will drip into the fuel. The water binds with ethanol in the tank and can eventually lead to a phase separation and engine problems.
By limiting the volume of air in the fuel tank you can reduce the amount moisture than can enter and condense into the fuel.
Oh boy...Ethanol - Just use the Startron.
Hey Mike, is that popcorn ready?
Fuel prices are much less than then 5 months ago, at least at the auto gas stations. Based on the past, the oil companies will raise prices as soon as they get the littlest reason to do so. I feel confident in saying the price of gas is about to bottom out and will trickle back up. Reg Gas is as low as $2.35 in my area. Now that fuel has dropped, so has the price of out retirement investments. In my opinion the chances of fuel dropping more than $0.20 a gallon over the the next 6 months is much less than the price going up at least $0.40 over the same period.
I use gas and will fill my tank up to about 3/4 full. I will run it more often/longer in the spring to use it up so I can start adding fresh gas (no water in it). I try and run the tanks nearly empty before winter adding as much as need for weekend. This way I can fill back up while in storage. My biggest fuel expense is in the winter.
