they work if you can reach teh vents from the deck or dock... i often cant' as they are placed too low on the hull. are the bottles transparent enough to see how much fuel is in ?
currentsea, not really. if the pump you're using is faster than normal and if your fuel vent gets restricted, you will spill. the little screens in the vent often corrode and restrict flow.
since my vents are near the ER intake and near the filler, i added 3 way valve to the vent lines, connected to a T and 6 ft of clear tube which i route thur the ER air intake and into the filler. no more burping out... obviously, it can only work if the fillers and vents are close to each other and accessible.
