Furuno Antenna Connection-Source?
Joeshoes
I have a Furuno 1850 GPS with the big egg antenna. The end of the antenna wire has a plug that fits into the unit and it disappeared.
I tried a few places and could not get a replacement. Any ideas for a source for replacement?
I think Boatfix sells some Furuno parts...or if not Google "Furuno Dealer Locator"
Can post a picture of what the connector looks like or give me a mod # of the ant.? I buy stuff OEM from Furuno. Perhaps I can get it for you.
I looked at a picture of the antenna doing a web search it looks like a "Male TNC". Now the only real problem might be determining the size of the coaxial cable either RG-58U or RG-8X styles are the most common. I have a NAVTEX receiver by Furuno and it's antenna uses a RG-8X style (cable physical properties) Male TNC connector. Almost any radio shop should be able to put a new end on the GPS antenna. Is the center pin still on your cable? Is there any visable shielding? If so you could probably located a solder type RG8X style connector and follow the installation instructions.
They made a crimp style too:
Mini UHF FEmale Crimp type connector for RG8X
$1.95
7603D, Mini UHF FEmale Crimp type connector for RG8X
Capt. Bill Mini UHF aka mini-PL, is different than TNC. Mini PL looks like a minature version of the standard connector on your VHF radio TNC looks like a minature version of an N connector found on commercial equipment operating from 900Mhz to 3ghz.the old original cellular phones except Motorola used TNC connectors as well. I could be wrong but mini-UHF or Mini-PL is only good to 800 or 900Mhz and that is pushing the envelope of the upper frequency limit. Again I am not 100% sure but the GPS connector on the Furuno site looked like a TNC male connector.
Thanks to you all. I will go to the boat tomorrow, if it stops raining, and get more info
Please get the model of the GPS it's probably a GPS017 or GPS019.
"Capt. Bill Mini UHF aka mini-PL, is different than TNC."
You of course are correct. Next time I just have to make sure and double check that I cut and paste the right thing before I post it. Duh! :-)
"TNC Male Connector - Crimp Plug for RG58 and RG59 Coaxial Cable
These TNC male connectors have been specifically designed for a crimp style attachment to both RG58 and RG59 cable. The connector body and clamp nut are machined and nickel plated for superior corrosion resistance and durability. Gold plating is utilized on the center pin for low contact resistance."
Bill you have been at this longer than me. So I meant no disrespect.
Joe if you can read the numbers on the coaxial cable I will send you 2 free connectors and a loaner crimp tool via UPS. I just ask that you return the tool ASAP. I am giving you 2 connectors in case you mess one up. PM me or better yet e-mail me. Bill
