Furuno GPS Chip
tip sea
I bought a 1998 Mariner that came with a Furuno GPS 1610. It works well, but does not have a chip for my area. Anyone know where I can get a chip for the middle Chesapeake River? I have exhausted all of the obvious, and am now looking to used.
Do you have any manuals? Is it a matter of not knowing exactly which chip to try? Boat Fix sells a lot of chart chips, have you tried here?
Furuno also has a chart card service, you may want to try them first:
http://www.furunousa.com/Furuno/Rooms/DisplayPages/LayoutInitial?Container=com.webridge.entity.Entity[OID[850D617B26DEFE40927C10599CB4C935]]
Here is a link to the manuals, BTW.
http://www.furunousa.com/Furuno/Roo...Entity[OID[56315385E29A1C43B4113613601483FF]]
On my '03 unit was available set up for EITHER Navionics chips, or C-Map, not sure if this applies to a '98 unit, but you may wish to confirm.
NOTE - if it does take ta C-Map chip, the Furuno version of the C-Map chip is a special size! Hope this helps.
