FWC News Release
Barq
FWC News Release
Northeast Region
For immediate release: February 8, 2008
Contact: Joy Hill, 352-732-1225 or 352-258-3426
Photo available at: http://myfwc.com/whatsnew/08/northeast/News_08_NE_Overflow_Photo.htm
Operation Overflow 3 nets 10 citations, 2 warnings
In this day of water woes and wars, it is hard to believe that some boaters dump raw sewage overboard right into Florida's precious waterways.
But the sad reality is some still do, even though the law says sewage from boat toilets must be treated before being dumped, or it must be held in an on-board holding tank until it can be pumped into a U.S. Coast Guard-approved pump-out station.
“Most marinas have pump-out facilities so there is little excuse for not complying with the law," said Officer Mark Tharp, a Florida Fish and Wildlife Conservation Commission (FWC) officer who patrols the St. Johns River and routinely checks boats for compliance.
Personnel from Crystal Cove Marina and Acosta Marina, both in Putnam County, recently reported raw sewage dumped in the water to FWC and Department of Environmental Protection (DEP) officers. Tharp, three other FWC officers and a DEP officer then teamed up for Operation Overflow 3.
Officers inspected marine sanitation devices (MSD) onboard vessels at the two marinas. They were looking for properly installed and maintained devices. What they found were more boats in violation of the law than in compliance. Out of 20 inspections, officers cited nine boaters for MSD violations, issued two warnings for the same, and arrested one boater on an unrelated, outstanding warrant.
“Both Crystal Cove and Acosta marinas are very proactive in educating boaters about the laws pertaining to dumping raw sewage. Unfortunately, however, this non-compliance occurs more often than most people probably realize," Tharp said. “Simply put, it's against the law to dump raw sewage into our waterways. In fact, in some waters it's also against the law to dump treated sewage, yet some boaters continue to ignore the law."
Since 1994 boaters have been prohibited from discharging untreated sewage into freshwater or within coastal saltwater limits. Coastal limits are nine nautical miles on the Gulf and three nautical miles on the Atlantic Ocean.
No Discharge Zones prohibit boats from discharging treated or untreated sewage into water bodies. In these waters, an overboard discharge valve must be closed and secured so no wastewater can be dumped. An open or unsecured valve is a violation that carries about a $250 fine.
FWC officers check the MSDs on boats all year long throughout the state, but the heaviest boat traffic in some areas is during the fall, when vessels are migrating south for the winter, and again in the spring when they're heading back north.
During last year's fall migration, FWC Officer Clay McDonough organized special details to check MSDs on boats traveling through the Intracoastal Waterway (ICW) in Flagler and Volusia counties. The detail included officers in boats as well as in the air. As part of the checks, McDonough dropped harmless green dye into the toilets and flushed to see if toilets were dumping directly into the water. Officers in the air could clearly see the bright green dye flow freely from the boats with open valves. The operators of those vessels got $250 tickets.
“We cited around 40 vessels during two details on the ICW last fall," said McDonough. “Even though compliance improved compared to 2006, it's still not good."
The following crafts are required by law to have a working toilet on board when in state waters:
* Any vessel 26 feet or longer with an enclosed cabin and berthing facilities.
* Any houseboat, defined as a vessel used primarily as a residence for a minimum of 21 out of 30 days in a county of this state, and this residential use prevents it from being used as a means of transportation.
* Any floating structure with enclosed living space with berthing facilities or work space with public access.
All marine sanitation devices must be U.S. Coast Guard-approved. All waste from portable toilets must be disposed of in an approved waste-reception facility or pump station. Restroom toilets at marinas or elsewhere are not approved reception facilities, become some of the chemicals used in portable toilets do not break the waste down to acceptable levels, nor do they kill disease-causing organisms.
The Department of Environmental Protection's Web site has more information about MSDs and how raw sewage impacts human health and the environment at www.dep.state.fl.us/law/grants/cva/cva_faqs_boaters.htm.
-30-
JH/NER
PCB
Joy Hill
Public Information Coordinator
Northeast Region
Florida Fish & Wildlife Conservation Commission
1239 SW 10th St.
Ocala, FL 34471
(352) 732-1225 Office
(352) 258-3426 Cell
(352) 732-1391 Fax
Joy.hillrb2@gr5tMyFWC.com
Visit us at MyFWC.com
From an earlier thread, I still do not know what "secured" means? Our Sea Ray has an interlock system where the sea cock shuts out and disables the Macerator from operating. The sea cock is not "secured", but you would need to go into the engine room, open the sea cock, go the the electric panel, turn on the Head Systems and turn on the Macerator. That would mean it would be impossible for an accidental discharge.
From what I have read elsewhere this is meant to have either a wire tie or lock on the "Y" valve. However, this article is very ambigious--it does nnot address that issue of "securing", nor does it address legal flow thru devices. Neither of these areas are "no discharge"--so that a lectrosan could be used--and of course the dye would still appear. That article implies that dumping a portipotty into a toilet is not acceptable (and possiably one of the reasons that the marinas were so co-operative. How often do you see "approved reception facilities"? Lake Powell comes to mind--I don't remember ever seening one of these on any of the ICW marinas--does this mean that you cannot dump your porta potty at home? Another question--one of my boats has the head dumping directly into the holding tank by gravity. The waste can either be pumped overboard thru a macerator or pump out--and that is controled by the "Y" Valve. Since it is closer for us to go out 3 miles to sea to dump than 12 miles to a marina, where the pump out only works about 30% of the time and the sewage is pumped from the treatment plant into the bay, we leave the "Y" valve in the macerator position, even though two switches have to be opened for this to work--it may not be "legal".
as much as i am all for clean water, i cant' think that using a helicopter to spot die in the water is not a waste of taxpayers money.
The rules are pretty clear. The seacock, Y valve or the macerator switch must be secured. that means pulling the handle, a padlock, a nylon tie or key switch on the macerator. I know we're discussed the key switch but it is legal since the UCSG official rules leave the door open for "other" means of securing.
Secure is teh key here.
Missnm if you dont' have a tie on the SC handle, put one on now.
I'm glad they're enforcing these rules, and i hope that this prompts more checks in marinas.
It is beyond me how anyone who is a boater can think it is ok to discharge sewage overboard. Even if you are outside the 3 mile limit, why would you do that? Unless you just happen to stay at sea for weeks, I just can't imagine how it could be that inconvenient to pump your holding tank. I had my cruiser for 5 years and never even turned the macerator on.
the problem is that there are many areas with no pump out, so it's quicker to run 3+ miles out than hunting for one.
let's be realist here, do you really think than 50 gallons of waste 3+ miles out in the atlantic is gong to have any impact?
Where do you think the untreated run off from rain storms goes from waste treatment plants? That is far more damaging than discharging at the 3 mile limit. I like Pascal like clean water as well but there are plenty of other methods and far more damaging than pleasure boats dumping 50 gallons of waste which at least 90% is water at the 3 mile limit.
Take care. Bill
Stupidity at its high point. Helicopters cost ~$5000 per hour to run. The ticket was $250. So far based on the story we are at a net loss of NEGATIVE $4750 in net ROI.
"FWC officers had placed harmless, green dye in the boat’s toilet and flushed to check the boat toilet facilities for compliance." Were the owners advised of this. Was a warrant presented to search the "toilet facilities" (head) and introduce the dye? The right lawyer will argue illegal search and seizure.
The only good part about this whole thing is it was a sailbote!!!! I guess they are so algore after all!
Last time I chartered in the BVI, boats did not have holding tanks and everything was discharged directly into the water. Needless to say we did not swim in the harbors.
Of course not, the problem is like most things, people are going to continually push the limt, stretch the rule etc. That's why you have people dumping in the ICW and freshwater lakes and rivers. I just think when you have the option not do dump, you shouldn't.
That green dye better not damage my Electro Scan!
If I'm in a NDZ, I can turn the key off (Pascal is right, it's legal or Raritan wouldn't set their systems up that way) and my 20 gallon tank will hold the waste. But outside of an NDZ, I can treat and discharge as I need. What comes out of an Electro Scan is cleaner than what comes out of municipal waste treatment plants.
If you're an honest person who doesn't dump raw sewage inside of 3 miles (or in NDZ's), just lock the door to your head if you think you're going to get boarded. That's legal too.
If you really want to dump millions of gallons of raw sewage with no consequences to yourself, just go to the impossible trouble to declare your vessel a legal municipality. Cities and towns all over the US dump raw, or under-treated, sewage on a daily basis into waterways.
Are the manatees aware that they need to go three miles out to defecate?
