Garmin 3210
jacko
Anyone have one of these?
The boat I Looked at has one. I boat in the Chesapeake / Potomac River. The chip in the unit is the Chesapeake chip. The guy said that he thinks it only covers the Norfolk area in the Chesapeake. Does this sound right? I forgot to get the code but it said it was the Chesapeake version when booting up. Would you recommend this unit? The software version was 2008.
It's a very good unit I have the 42 series not much of a difference. Get the chip you need and you are good to go. You can't go wrong with Garmin. I would be more concerned with the boat if it is half as good you will be happy.
I have a 3210, and it has the charts pre-loaded. Doesn't need a chip. You sure you have the model number right? Are you thinking of the 3010?
The 3210 deos have a slot for a chip, but I think it's only for updates or added features.
You are correct. Charts are preloaded.
George
As I said it's a good unit I almost bought this model as the 42 was just coming out.
Yes I am sure.
HEY! There is a guy in your GPS with a camera trying to get out!!!!
IIRC the slot is for specifics in the local area that may not be on the preloaded charts.
jacko - the seller is wrong. I have this unit and love it. It includes all of the coastal U.S. and great lakes. I bought the detailed chip for the Bahamas. There are 2 slots for updated chips. If you buy this, hit me up for an extra card reader I have on hand so you can download the updates and install them.
Yup - That photo sure shows a 3210. You should already have the charts loaded. Slots are for udates or extra features. But, all your regular charts are loaded in there already.
"Pre-loaded" charts can't be updated. The chart slot is for charts specific to your cruising/fishing grounds that CAN be updated...
I have a 3210 bundle. The slots are for updates but they also accept a bluecharts chips. I use the 18r chip for lake erie. Go here to see the chips avaiable for that area. These chips give greater detail that the preloaded ones.
Good luck
Niles
http://www8.garmin.com/cartography/bluechart/region.jsp?RegionPK=25363
Speaking of updates...if you don't have the special chip readerwriter Garmin has a program where they will send you a preloaded update chip, charge your cc something like $58 and then credit you $50 when you return the chip. I did these last spring.
I have a 3205 in which case the "32.." means separate control buttons and not touch screen and the "..05" means a 5 inch screen not 10.
The preloaded charts are more than adequate in the Albany NY area (Hudson R.) and around Key West.
BTW, "42.." is touch screen and I don't think there is a 4205 because nobody's fingers are small enough.
Good luck
Niles
I am thinking for $58.00 you cant go wrong.
If I end up with this boat I will look into that.
<<..."I have a 3205 in which case the "32.." means separate control buttons and not touch screen."..>>
<<..."BTW, "42.." is touch screen..."...>>
Actually, the "32" series means it has pre-loaded charts (as opposed to the "30" series which doesn't)
The "42" series still does not have touch sreen. The "42" series adds route guidance. You don't get touch screen until the "52" series.
You can get updated charts chips. I had a pair, replaced them with 4212 AND 4210'S. They use SD cards instead of the proprietary connector on the 3210. The 3210 also doesn't do NMEA2000. You can order the enhanced charts needed.
Thanks Glenn. I also heard the touch screen (52xx) is to be avoided on smaller boats that bounce enough to make its operation difficult.
I wanted to add a mistake that I made with this unit. Took some salt spray and slashes (seemed like the entire wave at times) through the bridge in some 8' to 10's on a fishing trip. I casually wiped the screen with a rag I had on hand throughout the trip. After we tied her up and started cleaning, I realized that I had rubbed a small patch of the anti-glare off the screen! Either the rag was too coarse or the salt from the dried water was the abbrasive and I didn't notice. Since the coating is a lacquer, the remainder couldn't be removed without damaging the unit. So, many months later of gentle rubbing each time we're out, I finally have it all off. No more anti-glare, sadly. But the unit still works flawlessly.
Just a word to the wise...
I had the same problem on my 10" Garmin but was using a Micro Cloth. After sailing the south cost of Puerto Rico all night I cleaned the screen in the morning after the salt water had dried and then noticed the bottom of the screen had lost some of its Antiglare coating. The Micro Cloth was wetted with distilled water any time I cleaned the screen. I think the salt water must have some chemical in it that softens the coating.
Garmin said they would repair the unit for $400.00.
I clean my screen with the same cleaning kit that I use on my Maui Jim sunglasses. It is a microfiber cloth and some sort of special spray. I get the kit from Sunglass Hut for $10. Works well, and doesn't do damage. Perhaps that salt was on the screen too long, and the damage was already done ??
