Garmin Plotter-Anybody seen this
dumy
On my Garmim 530 plotter an arc, or semicircle, red, yellow or white intermittantly shows up across the display. This plotter does not have the fishfinder.
I called Garmin and the rep could shed no light on the situation.
This does not interfere with with readability or anything else. I just like to know what I'm looking at.
I am using the St Lawrence Seaway chip, which includes Lake Champlain.
Any ideas??
Thanks.
Ron
i used to have an odd issue with an older Garmin... forgot the model... 98 vintage... 221 maybe. in one area near the Key Largo, zooming in who cause the shore color to bleed into the water. your problem sounds like another type of graphic problem. have you tried zooming in or out ? maybe move the pointer ?
Pascal-Yep moved pointer around etc. Usually run it between .2nm and .5 nm scale. It just comes and goes at will. It's a very slim line and doesn't effect view. I was surprised that the folks at Garmin couldn't explain it. Will fool around more with at first opportunity.
Ron
don't know how long ago you bought it but see if you can take a photo of the problem and return it under warranty in the fall - if it's still within the year.
Les, Thanks for the suggestion. Bought it from Boatfix in April.Never thought of taking a picture.
Sure it's not the arc for navigation lights? Some systems draw a semi-circle that shows where a light would be visible. Dunno if that's a feature on this chartplotter though...
wk- That's a possibility. Will check it out next time aboard.
Maybe a set of younger eyes would fix it!!!!!
I have a Garmin and I have seen this circle come on my screen too. I think I remember reading something about the circle mode coming on automatically when you zoom in pretty close. The ring shows the boat location +/- 20 feet error. The circle is the 20 foot arc around your boat.
This is from my memeory and I am not 100% sure about my response.
Earl-was wondering where you were! CCruiser-arc encompasses larger area.BTW,I was in error in my post regarding scale I use. I usually have the display showing between 1 mile and 2.5 miles. I kind of like the nav aid theory from wk99. Will be a while before we get to the boat again,but will let you know what I find out.
Thanks, Ron
Mine does the same thing. When Zoomed in it puts a circle around the boat.
Bump up here. RO wkerney nailed it. The arc is the radius covered by navagational lights. Shows up only on scale of .5nm or less. Thanks to all for your input
Ron
