For whatever reason, my fume sensor has gone toes up. If a fuse is put in, the blowers come on and will not shut off even with the hatch open. The boat is a '99 and Xyntex says the sensor is good for about 9 years. OK, no biggie. I am assuming there is no way to "clean" the sensor. Questions:
--Is there a way to clean or "fix" the sensor. Yes the boat is 10 years old, however, the boat was out of the water and engine less from June 2005 until February 2007.
If the sensor is NOT fixable...
--Should I just replace only the sensor or the whole unit dash piece and all. The sensor is ~$70 and the whole unit is ~$170. I do not want to spend the extra $100 if not necessary. However, I don't want to tear things apart twice either.
Does the dash unit ever go bad as well?
Here are the parts in BF.
http://www.boatfix.com/catalog/18.pdf
Part numbers:
MB-1R / FRBMB1R--Whole unit.
MS-2 / FRBXMS2--Sensor.
TIA
Part numbers:
TIA
