Gas Tank Locks?
Pigmeister
What do you think, do we need to put locks on the gas caps with fuel hitting the Stratosphere?
Well, it might encourage thieves to go to the next boat instead of yours. Another alternative is an anti-siphon adapter. But the lock is easy to see and may prevent a boarding of a boat.
Unfortunately the only ones I have seen so far are from Perko. Perko products today are junk. Most of their stuff is made from Zamac or other mystery metal.
Al
most boat have a sharp 90 degree fitting on the tank where the fuel fill hose clamps on, often we pull the fuel sender to get fuel or water out of a tank so you might have a perfect solution to a non existant problem
Also,many fuel tanks are below the water line, so siphoning won't work. They would need a pump of some kind to get the fuel out.
Wen: that tank lock certainly is a beautiful product. But it has two glaring design errors:
1) The key slot is exposed. It will almost certainly collect salt ( which will crystallize )/and or sand, jamming the locking mechanism.
2) When the large diameter threads begin to collect miscellaneous crud, it will become difficult to unscrew. And you will be attempting to open it using a 3/32" x 1/4" brass screwdriver ( the key ). The key will almost certainly break, in the lock.
Too bad. It was a nice approach to the problem.
Vetus has a spider-like thingy that goes in the fuel fill hose to prevent a siphon or pump hose from transitting down the hose to the tank. Two sizes (1-1/2 in or 2 in ID, I think), for about $35.
Bill you found the flaws, I have a hard time getting my standard one off with the tool.
Ken
Hey guys, I didn't design the thing, nor did I recommend it.
However, while the locking mechanism is indeed exposed to the elements, in use the locking part of the cap is first unlocked and then removed, thus allowing the use of a standard gas cap wrench to remove the treaded portion of the cap.
If the locking mechanism is kept relatively clean by normal periodic washing of the boat itself, I'd guess it would probably work out just fine.
