Gas vs. Diesel
Moderator
So with all this talk about re-powering with diesels, I thought I'd weigh in with my personal experience.
I owned gas boats for 20+ years, I put thousands of hours on the engines, regularly maintained them and never had a catastrophic failure.
Last year I moved up to a 44' Trojan with twin Cummins diesels. We put over 70 hours on them this year, going from NY to the Chesapeake and back.
The good: Plenty of torque/power, set the throttle and forget about it, regardless of wind, waves or seas. Run strong. Better mileage. Diesel fuel is cheaper.
The bad: I hate the diesel stink and soot on the boat. Parts are more expensive. Much slower response to throttle action.
Verdict: I'm not one who says "once you go diesels you never go back". For a smaller size boat, I'd go with 8.1's and be a happy camper.
I've got 145 hours on the engines so far this year (pushing 800 total hours). They're Honda outboards, and I'm hoping to get a few thousand out of them. I'm very happy with outboards. But to be honest, I'd rather carry diesel fuel around than gasoline. It's just safer in my opinion. I'm of the mind that I'll buy another outboard boat with gas, but if I ever go inboard, I'm going diesel. Now for you inboard folks, I hear what Hogan is saying. But there's a big darn question coming up for all of us "gassers" and that's the ethanol crap. We might all go diesel soon (until the corn lobby -CONAGRA- messes with that as well).
By the time E 15 is mandated, I'll be dead and gone... Not a worry for me.
Mike how small? Mine is actaually a 41' about 44 LOA. It's heavy over 28,000 lbs before I add the Splendid washer/dryer combo.
Under 20,000 lbs, 8.1 fuel injected gassers...
Mike, those are the only drawbacks I also find with diesels. The soot I handled with an inch o pitch off the props so I am a full 100 rpm over max at WOT. The diesel smell I found was a small fuel leak at the tank sender so I had to wash down th whole engine room with dawn after fixing it.
If you can get some biodiesel and run 5% bio you will smell more like a McDonalds burger joint.
Hmm, not sure if that helps a lot.
While if my boat had diesels I would be happy but I wouldn't trade my boat for one exactly like it with diesels. I have never felt the boat underpowered or sluggish like some others of this size.
The only reason I would ever have diesels would be in a larger boat than what I currently have. I do believe I am right on that fine line of needing diesels but just under.
The fact is that not everyone "needs" diesels. However, everything with E10, etc. is very concerning. I have had 2 clients have to completely pull their gas fuel tanks and redo a bunch of stuff due to E10. In this market though, there is nothing more difficult to sell than a larger gas powered boat and the price they will bring is terribly low! But hey- I've sold some very big gas powered boats this year to people who specifically wanted gasers as they hated the smell of diesel.
For me though, I love our little Perkins 6.354 inline 6 single screw. Like Gary, I found our strong diesel odor when I first purchased her to be via leaks: 1) fitting leak at injector pump, 2) one of the actual injectors leaking, 3) and most bizarre, discovering the previous owner's method of changing oil....dumping the oil directly into bilge below engine which is 100% separated from any bilge pumps and it's own little bilge area, then pumping it out with a bulkhead mounted pump. Just fixing the leaks alone cut down a ton of the odor. Soon I am going to scrub the bilge down top to bottom and then paint the bilge. I am also going to seal any/all penetrations between bilge and cabin. Just fixing the leaks reduced the initial odor at purchase from strong to minimal. I think once i clean the bilge I'll be able to really kill the odor. but yes, diesel boats always have a slight smell to them but luckily I kind of like it. :)
Would I go back to gas in a large boat? Not at this point in time whatsoever. Even with just a single screw, that prop digs into the water better than the gasers ever will and if I install a bow thruster to negate the prop walk in reverse, I think I'll be able to handle her as good as a twin screw.
Soot....not a problem for me but we're only doing 8-11 knots! :)
It's not the diesel fuel, it's the diesel exhaust that I hate.
i am working on a regal 37 footer with yanmar 260 hp V drive diesels one engine overheated so they ran on one the black soot covered the entire interior like a black electrostatic coating the vinyl seats too the swim plat form is as black as if you painted it i will take a few pics but besides that here is the little yanmar problem... overheating cracked the aluminum exhaust manifold its 3000 heat exchanger 2000 pistons and liners 750 each times 6 gasket set 500 250 for injector gaskets 8000 for the turbo if its damaged yanmars are a cheap power option till you try to rebuild them the parts are nutz! just finished a boat a merridian 411 with the new cummings 480 hp they are impressive no smoke even going thru the turbo island into boost and they are very quiet even in the engine room very impressive
Previous boat was a 1998 Cruisers 3860 with gas engines. As with all earlier boats, was a lake boat and never had problems with the gas engines on the lake. When Lake Lanier went dry (2002?) moved it to Florida on the salt water. Even with sealer coolers, the impact of salt was such that at 990 hours had to rebuild. Bought a Regal 4460 with diesels in early 2006. While only 550 hours thus far, they are running strong and appear to only be getting broken in now. Guessing that I will get at least 5,000 hours before rebuild. Until then, benefits are:
• Running diesel which is cheaper than gas;
• Swinging bigger props, maneuvering at docks is much simpler;
• Fuel economy went from .58 mpg to .95 mpg.
For me, will never go back!
I'm not putting Yanmars in Kevin. Looks like IVECO or Cummins not positive yet but leaning towards IVECO's.
Bill what about service?
Since my marina is going to be an installation and service center when in NJ no problem. I do have to check in NC. However these engines look idenmtical to the Cummings line. I have not decided yet.
Overloaded?
I had some volvo's that smoked and a pair of perkins, but those were old designs. But even my cats burn clean and they are 30 years old now.
Soot AND stink sounds like possible overload. Make sure those engines can exceed the minimum WOT rpm by at least a hundred rpm, more is better.
Mike aren't the exhaust ports on your boat at the start of the cockpit? Your also on the same level with my flybridge high and rear exhaust at the water I might not see the problems your are?
Great post Mike,
My original no knowledege reason for not having diesel was the smell and cost. My other concern was maintenence. I do all my own repairs and maintennace, gassers are simple.My boat is 19k dry, but Silverton specs are something you should not bank on.I have 8.1 gassers, boat moves fine, 21k cruise 27k WOT. Handling around the dock is more about the hull and the sail, not the torque.
I will add safety to the list of pros. If you have ever been on a boat/jetski that had blown up you think about safety a bit more. It doesn't take much of a leak to cause devastating results I'm lucky to be alive.
I don't mind the smell of diesel on my boat it only smells as I first get on plain then I don't smell it the rest of the day. Many newer diesel boats are cleaner burning and have underwater exhaust with very little smell at all.
I'm not saying I will never own a gas boat again but I'm enjoying the diesels I have now.
Overloading diesels results in excessive black smoke and premature failure.
Make sure you are reaching WOT on BOTH engines.
Barnacles on the props or a prop ding can silently create this problem.
As far as the costs of repair, the costs for sensors and electronics and most of all the DIAGNOSSIS on new technology gas engines is far greater than th ecost to repair a stuck carburetor float or replace a coil on an '80's 454.
Same with diesels.
I am FORTUNATE to have a new technology diesel that does not require any electronics or sensors. As long as it can crank and the electric fuel pump runs, give her an air & fuel supply and she will start and run.
Yanmar parts are more expensive than Cummins parts.
The 6LP is assembled in Georgia.
