GeeBee, SOSpenders Question
SailArmy
I'll be flying Delta to Honolulu from Virginia in August & return about 5 weeks later for work.
I want to pack my auto-inflate SoSpenders (plus a recharge kit) in checked baggage. I've checked the Delta site for guidance and it seems like that is doable.
Anything you can add that would pave the way for success?
I haven't call Delta yet, except to ugrade to 1st Class.
Thanks for your time.
Sure can. As a matter of fact we are one of the few airlines that allow these units as carry on as well. See this table under "Personal Flotation Devices". I suggest you print out this page if you do carry on as the TSA screeners sometimes think all airlines ban them. We do not. Also, I would print it out and throw a copy in your checked bag with the PFD section circled. TSA is not the brightest bulb in the shed.
http://www.delta.com/traveling_checkin/baggage/special_baggage/dangerous_goods/index.jsp
What do you guys think about auto inflate versus manual (pull the rip cord) inflatables. We have a power boat and go offshore. I realize if you got knocked out then you want an auto inflator. But I like the idea of being able to swim with it on not inflated. Maybe boarding the life raft in an emergency, with it not inflated. Swimming after a kid in an emergency situation with it on but not inflated etc.
I know that mine had an insert that allowed you to "manualize" the vest. Basically, the auto bobbin is removed and a plastic "blank" was installed in its place and the rip cord still worked.
I happened to like the auto version, as I almost always single-handed and the head banging potential is always there. If I wanted to use a non-auto unit, I had one aboard ( for non-swimming guests, which is recommended... )
What you might consider is a) wear an auto-inflate vest. b) also wear a manual belt-pack type ( they are not large ). If you want to jump in after a child, discard the auto ( they come off quickly ) and dive in. You will still have the manual belt-pack type to use as needed. And if you do find yourself in the water as the boat continues along merrily, having the second vest could prove useful ( if for no other reason than providing a larger visual target )
If I were boarding a life raft, it would be inflated...
If you want to deflate it for swimming, just reach up and press the valve on the manual inflator, you can selectively deflate it. Auto is for when you get thrown over board, your head hits the gunwhale and you are knocked out. You want it.
GeeBee,
Sorry for the late reply, been out using the auto-inflatable for work.
Thanks for the link and info.
My team and I will put the info to good use.
