i copied this from another forum. haven't tried it but it sounds good>>>>
I use a Gem 10" orbital polisher. For burnishing the polish on, generally, you put the polish on the pad and go to it, only you don't let up or quit until the place you are polishing shines as though you are done. Only then do you put a terry cloth towel under the polishing pad and finish up.
The theory or rather science is that the heat generated by burnishing is necessary to get the polish you are using to fill the micro pores on the gelcoat and get the uv inhibitor to stick. Could be snake oil, but I've used this system since 1992 and my boats, even though they are not new, consistantly look better than the dealers unsold new inventory. I am frequently asked by dock walkers who are shopping: "Is that boat a new model.....I can't find it in the catalog." Makes you feel good and lets you know you are doing it right when a 9 year old boat is confused with 2005's
With this system, I only use terry cloth covers over a foam buffer pad. The cleaner and polish both go on the same way, applied directly to the terry cover, turn the polisher over and go to it. When the polish is almost shiney, I put a clean terry cloth towel on under the terry cover and polish to a shine.
I only use a cutting compound when I have a lot of oxidation.........usually on the hull sides since I only wax it once a year. I use a Milwaukee low speed rotary polisher with a wool pad, not an orbital for that. Once the glass is clean then I use the cleaner and polish as described above. If I am where I can get compressed air, I use an air polisher with a foam cutting pad for the compound and cleaner since you can slow them down to the point of stalling by reducing the air pressure.
As long as you understand the situations where you should use a rotary or when it's best to use an orbital, then you will make the right choice. I personally have found this site
http://www.properboatcare.com to have a lot of good information on the subject with a lot of good how to's . Obviously, they want to sell their own products but if you read their write-ups they do a good job of explaining which buffer should be used given the condition of your boat. You will find Costal Tool's price to be among the lowest out there for the Porter Cable Orbital (that's where I purchased mine) and they also give you the loop pad adapter (very important to have this) for attaching your pads. Pad selection is also very important. I use Lake Country Pads myself
http://www.lakecountrymfg.com/foampads.html and there are a variety of pad densities each designed for a different function (example......polishing versus applying wax).
My suggestion would be to do as much research as you can on the whole subject of polishers, pads, and waxes/polishes before you make that purchase. I have both a rotary as well as an orbital but I have seen people at our Marina make mistakes and waste a lot of time by not understanding the whole process of buffer and pad selection
