generator runs 7/24
TimHenn
My boat is setup that the Benny needs to run 7/24 to keep the fridge, freezer and air control systems running along with several other things. Unusual? Apparently some places have noise ordinances and expect the generator to be off over night.
I don't know why they didn't wire the fridge/freezer to the batteries because they are both dc capable.
I want to be your service man. Let's see, every 4-8 days an oil change? Every 30 days new plugs (unless it is diesel) and about every year or two a new genset.
Is this for real? Why can you not plug it in to shore power?
No, no, run runs fine off shore power. Tis is when on the hook or mooring ball. I generally don't go more than 2 nights off shore power and yes it is diesels.
Pretty typical on larger boats with 120v refrigeration but if yr fridge can be run on DC AND you have enough batteries then it s worth residing it
Up north, yr best option is to add an inverter and an inverter bank since you don't need air con that often. It will pay for itself in a year or so
Been there done that
Thanks Pascal - good to know it's not something wrong. I have an inverter but they just didn't wire the dc side of the grudges to it. I will look into getting this fixed so I have the option. It's always good to have the option.
The good sailing folks at cut will have to put up with me for one more night..
Tim
"I don't know why they didn't wire the fridge/freezer to the batteries because they are both dc capable."
In most cases they do. If they are DC capable you could wire them up yourself.
Refrigerators draw a great deal of current. Our boat had to have a short haul last season because of a seacock leak. I forgot to turn off the fridge. They're AC/DC. Over night, both batteries were just about dead. You need to check the current draw of whatever you want to run and then calculate the size and number of batteries and inverters you'll need. I think you may find that, in the long run, it's going to be cheaper to move to a marina with shore power connection, rather than a mooring. If you need/want to moor, you may have to turn off one of the refrigerators to save power. Hy
Our diesel genny runs 3 hours on a gallon of fuel with the 16,000 btu AC running here in FL.
Both fridges are 120v and with no inverters we find it easier to just run the genny when we are out.
Once in a while it is nice in cooler weather when on the hook to just chill out with everything off and enjoy the sound of water slapping on the hull.
OK, so it is not 24/7, just when you are off the dock. Freezer/Fridge, if it is capable wire it up. Not hard to do.
Air systems, got to run the genny. What else you got?
What are you worried about? You wont wear it out. I asked around how commercial guys handle oil changes and the most common answer was 500+ hours.
I installed a xantrex 1800 inverter, charger with auto switch and 4 group31 batteries. I unplug shore power and the inverter comes on automatic and I have lasted 4 days with it on running fridge, microwave, coffee maker and TV without shutting it off. One of the best things I bought for the boat. Not cheap, but very nice to have 110v all the time while on the hook. Just got back from a raftup that started Friday night and the batteries were down to 12.2v when I plugged back into shore power.
I dont have ac, and I hate to listen to generators, so it works for me.
"...you don't need air con that often.." Well, we run the AC units all the time -- there are total of 4 onboard including the bridge. The forward and aft units are on nearly all the time, moisture mode when away from the boat. There is a large port hatch over the master but the other two staterooms have no such thing so you need air (the continuous fan at a minimum) to sleep. This boat was really designed to be run, including the air, I believe with 120v power. There are three refrigerators on board but I can shut them off at each fridge or circuit breaker but not the main fridge in salon (or freezer).
I'd love to know actual fuel consumption under typical load. I've been using 1/2 gallon an hour but when your out 2-3 days that's alot of hours.
Would still like the option to run critical systems off battery if needed but I think that would have to include the AC units which likely draw a good deal of current.
Again an inverter is the way to go, along with additional batteries as you will be as to run refrigeration, electronics etc
Not air though but again imfind that even with the poor natural ventilation so common on modern boats up north you don't always news air con at night. I was up there a few times this year and while some nights where warm they were many where a fan would be enough Air is not as critical as down south so an inverter makes a lot of sense
I use synthetic oil and bypass filters. I change the oil in the gennys once a year.
Wow, this setup sounds ideal to me... and may even cure my list problem. Dvan, do you have a more detailed description of your setup? Exactly how it is wired? Are the 4 group 31 separate from the start battery? What do you use to monitor performance?... etc.
--Rick
you always want your inverter bank to be independent from your start banks, and ideally your house banks. you also need REAL deep cycle batteries, not start/house combos.
most inverters have built in transfer swtiches. What you do on your panel is split the loads that you want to be inverter powered (Call if group 2) from those that will not be (Call them group 1). Typically that's water heater, air con, battery charger.. you add a breaker to that group 1 which feeds your inverter. the output of the inverter comes back to the panel to power group 2 which will be inverter powered.
as soon as you disonnect shore or generator, the inverter takes over.
the best batteries for inverter are golf cart batteries. two of them in series will give you 12v, you can parallel 2, 3, 4 pairs... depending on how much autonomy you want.
Rick, this works great for me. I have 4 group 31, 1150CCA, dont remember the AH, gel batteries. As I said it wasn't cheap and a xantrex 1800watt inverter, charger with auto switch.
I have a 2850 Bayliner with twins and had 4 batteries in the stern, which made my a$$ sag a bit. So I got gel batteries and installed them in the center compartment of the V berth. I installed the inverter in the compartment next to the batteries. I had to install a vent in the compartment to get ventilation for the inverter. Check out the Xantrex inverters, I think they had a 1200 watt inverter with a 20 amp charger also. Which probably would have worked for me, but I went with the 1800 watt with the 40amp charger.
As Pascal said, you wire it into your breaker panel so its all automatic when you unplug the shore power it switches from the charger to the inverter and you have 110v power to your boat.
I have went from Thursday night to Sunday night and the batteries got down to 11.9 volts. Thats with running the fridge, microwave, coffee pot, fan and the TV, which my wife leaves on most of the night.
As I said, I dont have AC on the boat, so I like this better then a generator.
Almost forgot, the Xantrex comes with a good monitor which shows the volts in your batts and the amps for the charger when charging them, also fault codes.
The only thing is that Xantrex quality has been up n down, mostly down. Lots of stories around about people having issues with them, my freedom 30 had to be repaired twice under warranty and failed altogether a fee months ago
I prefer Magnum, and they are made in the US not red china
Xantrex used to be the standard in inverter and charger some years ago, not anymore
I have 4200 panda and 2000 freedom which just cost $475.00 on my Hunter sailboat and my ref was hooked up to always run on 12 volts,I changed it to auto ac/dc because in my slip always have ref on and it would run shore power and not just 12 volt and need recharge batteries always.
I do anchoring out alot days and weeks so no way I am running that much but just to run ac and recharge batteries,4-6 volt T-105 and run 1 ref and 1 freezer and 2 computers droid hotspot internet microwave,electric coffee,dvd and only run gen when needed mostly 1 or 2 in morning and than a few hours at night running ac and all above.
Sorry me typing left handed me righty, arm in sling rotator cuff surgery.
