Go-Light remote control spot light.
Tommy Allen
I have a 24' HydraSports Walk Around with a hard top. We are making our yearly night time ride to a flotilla and fireworks display. I'm afraid it's going to be a bear to use a hand held spot light.
Is a Go Light a good remote? And I guess mainly, I've heard they are hard to control. Is that true?
And lastly, is the top of the hard top a good mounting location or will it light up the front so much as to blind me?
Thanks.
I have a remote spotlight on the arch and there is a definite glare on the foredeck. It gets pretty bright and ruins your night vision. It also reflects off the bowrail a little bit too. I wish it was out on the bowrail, but it's too much work to move it. I have no experience with the Go Light. My Guest 502A was ripped off by a spotlight eating tree while driving from Spokane to the San Juans. I was bummed and will replace it during the winter layup.
The company I work for has Go-Light spotlights on their 45 footers. Difficult to control is a grosss understment. Lets just say that I always bring my hand held when I run the boats.
Mounting on the bow pulpit gives the best light, without illuminating the foredeck. I have had spotlights set back on a flying bridge hardtop, and the foredeck was pretty well shadowed, when the light was focused some distance away. I have only used hard wired spotlights. I use mostly low power hand held lights on the smaller boats. The Vector VEC 156 CF (1 million CP--3 brightnesses, rechargable) is my favorite--often the lowest power setting is ample.
Once you use the spotlight--you have lost your night vision. We only use the light to ID marks or if necessary when docking. We keep one eye closed, and have one crew member use the light, the other close his eyes to avoid loss of night vision. 99% of the time a light is not necessary. You certainly don't want to leave a light on all of the time.
I have a GoLight Remote unit and it works just fine. Most people just use it with the default setting for speed of movement, and that is why they have trouble controlling it (it moves too fast). However, "the speed of the light rotation can be controlled by depressing the +/- button one time and by depressing it again to restore the original speed." Also, it is important to mount the Spot light as close as possible to the tip of the bow to reduce glare off of the deck. Lastly, the spotlight should be used sparingly, not like the headlights of a car.
I have one also, and have been happy with it. It's not nearly as bright as the high dollar mounted spotlights though. I bought a 3M CP handheld so I have brighter light if I need it. Although all these different ratings of candlepower are pretty much a joke. One of the magazines should do an actual rating on some of the stuff on the market, so we mariners know which one to buy. The 3M CP I just bought isn't as bright as the 1M CP I had before.
My GoLight is mounted on the very front of my top, and no problem with glare as long as I keep it pointed correctly. I wouldn't mount it on the front of the bowrail. At least not on my boat. And as Nomore10s said, no problem with moving it.
I only use mine maybe a dozen times/year, but nice to have it when it's needed. I use it just to help me mark buoys/posts when it's particularly dark or foggy. There are better spotlights on the market that are brighter and will last longer. But for the money, I'm happy.
JB
I know this sounds crazy, but we put black tape on the back to reduce the glare. We hardly ever use it. We can usually see better without it. We use a handheld sometimes at dock, but just for a short period of time. Future goal is to have a good spotlight mounted at the front of the boat.
First, the light would only be used to spot markers and would be used in short bursts.
I got the chance to see a Golight this weekend. I like it a lot. The light was mounted about 2 feet from the front of the hardtop and the owner said no glare problems or lighting up the bow. I oredered one this morning.
Thanks to everyone for their comments.
