I did the rope only 500 to the rope and chain 850. It is indeed "Plug & Play" and I did the swap myself. You will have to angle the existing hole where the rode enters the locker though. It was easy to do with a simple Dremel tool. They even provide a Starboard plate to put down before the new windlass. They also include a stainless swivel joint and shackel. I installed the rode in a parking lot while the boat was hauled, so I ran several layers of tape around that shiney new swivel so I wouldn't tear it up.
I think my total install time was less than 20 minutes. Simple stuff.
My only after thought was to increase the amount of chain. If I recall, the new ones come with just 10' of chain - stock. They do offer more.
After using this windlass weekly for about 18 months, I can say that I'm very pleased with it. The 850 has a "free drop" feature that kicks in at 3 seconds on the switch. If you only want to let a little rode out, you have to bump the switch. Once you have the right amount of rode out, simply press "up" on the switch to lock the windlass.
