GPS antenna question
kindredspirits
Hey guys, couple of questions. I've got a Raymarine 601 chartplotter with a Raystar 108 gps/antenna. The gps wasn't working so I pulled the dome off the top of the antenna and looked inside. Tons of corrosion, the unit was toast. I found another Raystar 108 on ebay and got it fairly cheap, but when it arrived I noticed the cable had been cut. Can this cable be spliced to my current cable which goes into the radar arch or is this a bad idea? I would rather not break the seal on the GPS antenna if I don't have to. Any advice appreciated.
Chris
The manual says the cable can be cut. Looks like there are 6 wires to connect (including shield). Google the Raystar 108 to get a copy of the manual.
I tryed to open my Raystar 108 and couldn't do it. How did you get it open? Thanks.
Bliss,
The top unscrews from the base, but you have to want it. When my original unit started giving me problems I opened the top for a "look-see" and found tons of corrosion. There are two circuit boards in there, I'm not sure why Raymarine would put the boards in the antenna. Don't most manufacturers put the boards in with the display? More protection.
"but you have to want it." Are you saying the top half of the "ball" unscrews?
exactly, mine was mounted on my arch and has a secure base. I was able to grab the top 1/2 of the sphere with both hands and unscrew it counter-clockwise. It was TIGHT. Around the circumference of the sphere you can probably see the rubber gasket that seals the halves. Once your in there you'll see the GPS antenna on top. Under that are two circuit boards stacked on top of eachother and seperated by spacers.
Are you having problems with yours? If you dissasemble it make sure your seal is in good shape before you screw the top half of the sphere back together and I'd make sure it is plenty tight. Otherwise, any water/condensation that gets in there will cause problems.
Many of the newer NMEA2000 GPS antennas have the receiver in the puck. This allows the signal to be stronger because you have no RF cable losses. Almost all GPS antennas have an amplifier in the antenna.
The seal on mine is hanging out around about four inches of the diameter. Amazingly there are no operational problems. (YET!) I tryed to unscrew the top half. It wouldn't budge.
tough call on whether I'd disturb the shell if it is that tight. If you happen to break yours let me know, I've got a spare shell you could have.
Many thanks for your kind offer. I am inclined to leave well enough alone for the time being. Thanks.
No problem, the members on this board have helped me out alot and it would be nice to return the favor. The offer stands as long as I have the old one.
Go over to Boatfix to find Maretron splicing boxes and numerous other Maretron marine electronics accessories. You can pretty much do anything with electronic cable problems with Maretron stuff.
I searched the Maretron line but couldn't find a "splicing box". The stuff I saw looked nice, but I'm looking for a "clean" way to splice two cables together and protect them from the elements. Any suggestions?
Yep, that's the reason. And there's nothing in there that's "user servicable" so there's no good reason to open it.
The best way to splice this cable would be to strip and solder each wire and cover the splice with heat shrink tubing. Then cover the entire group of splices with heat shrink tubing. The adhesive lined kind is best.
You may be able to stagger the individual splices so you don't end up with a big "lump" in the cable.
I believe Maretron recommends waterproof junction boxes for GPS cable splices. Their site has a lot of how to information. There is nothing wrong with Ron's soldering recommendation if it best fits your requirements but if a very small junction box will work it is much easier and will work at least as well as a couple of perfect solder joints.
