GPS-- Internal or External Ant.?
Planecrazy
I am looking to add the gps and wondering if anyone has had good luck with the internal antenna? I have a gps for the car and it always works great on the dash. so why would one for the boat be any different. I dont have an arch or anything on this boat so, short of buying an extension pole for an external the antenna, the antenna would be mounted on the side of the boat. By the time i purchase the pole, mount, and gps itself, its $100 more for the external antenna. Just wondering if its actually worth it.
Internal antennas are fine, so long as you don't have a hard top and don't flush mount the unit. Flush mounting is either: not possible w/ an internal due to physical dimentions; or possible but will block the signals. Like all GPS antennas, it needs a clear view of the sky.
I had a Garmin 192c w/ internal antenna mounted to my dash and it worked perfectly under my canvas top.
Like in your car - if you chose a spot on the dash that has good view of the sky it should work fine
We have an internal antenna and it works fine under our bimini.
Thats what I thought, and i get to same some $ too.....thanks for the help!
I have an internal on my Lowrance GPS on a bowrider -- no issues and it works fine --- fast screen redraws and no loss of signal. (so far -- only had the unit a month)
I have a Garmin 498 with an internal antenna, which works fine both under the bimini and down below in the lower helm (mounted on top of the dash under an angled window).
Orcbait
Garmin 182 with an internal, works on the dash and also in the cabin.
I was going to get an internal antenna Lowrannce 339. I ended up getting the external antenna version 337 because of how the NEMA 200 works using a fuel flow meter. I wanted to get MPG measurements and it required an external antenna on the NEMA 2000 bus.
