Great vacation, then...
jrekemeyer
Spent a fantastic week on Block Island, perfect weather, great swimming, clamming and fishing. On our way back to port my son was at the helm and my wife and I relaxing on the bench seat in front of the helm enjoying the ride back to Warwick Neck. Life is good.
But not for long... At one point I sensed a slight vibration that slowly worsened when my son comments, "dad, something doesn't feel right". He backs off the throttles and every thing feels fine stick my head in the engine room. Nothing dragging behind, no vibration, etc.
He throttles back up and shortly after the vibration starts again when bang, engine screams and and a hard veer to starboard. He backs down on the throttles again and I dive for the engine room to look for water/issues. No shaft on the starboard engine with a small stream of water coming out of the shaft log. Small I say? While, fortunately, the shaft snapped at the transmission coupling and the prop lodged itself against the rudder and the only leak, was the key way. I looked reassuringly, well sort of, at the zip-lock bag of wooden bungs taped to the bulkhead and located my hammer.
Now comes the realization that there are 3 folks I need to notify. My wife, "yep, that was a $1000+ noise, not a $100 noise. Radio the CG Point Judith to make them aware of the situation in case we need assistance and call TowBoat/US to come get us. Meanwhile, we had left early to avoid the winds so seas are slowly building astern as we made our way into the West Passage of Narragansett Bay. To make matters worse, anything more than idle, and the prop from the loose shaft would start turning and bang against the rudder making an awful noise. Next order of business, secure the shaft and prop, but the boat is moving too much for my liking to free dive under with a mask so we head to Dutch Harbor to grab a mooring so I can dive under. At 2.2 kts, bucking a tide with opposing winds we were getting nowhere fast and our stern was starting to get pushed around by the waves that were building to a steep 4-5'. At this point I was concerned that turning the rudder too far would cause the propeller to jam the steering hard and then we would be in a world of hurt, but with little steerage way, and building seas it was hard to avoid. Called TowBoat/US for an ETA and they we only a few minutes away. After a few moments of maneuvering to get the tow rope on I instruct the tow boat captain to head for Dutch so we can secure the shaft as we still had 12 miles to go. Notified CG Point Judith we were under tow. (I knew paying that tow insurance for years would eventually pay off!)
The tow boat takes us along side and we grab a mooring. The tow captain is also a diver with equipment on-board so the decision is made to pay the flat rate for a dive and let him tie it off right and assess the damage. Prop shaft is now back against the coupling, the water stream down to almost a normal drip, and a report of no obvious damage we get underway. He drops us back to a long tow with no banging and we settle in for the 2 hour trip back at 5.5 kts.
Back at the dock, we work through the paperwork with the captain, call CG station Point Judith to let them know we are back in port and take a deep breath. We clean up and the family takes off for home. I decided to stay on-board for the night to monitor the shaft for leakage and asses the situation with my last cigar and libations in the cockpit freezer. As I though back on the events of the day I was pleased with how my son and I handled the situation, but then the harsh reality of all the things that could have gone wrong start to materialize and how fast things can go wrong on the ocean. What if the tow was another 20 minutes away with seas building the way they were? What if the rudder did jam and we turned beam to the seas? The wind would have pushed us right into Bonnet Shoals real quick. What if? What if? What if?
I must have rehearsed calls to the CG and TowBoat in my head hundreds of times over the years, but when you actually make that call you know all those things you read about rehearing and preparing emergency plans and actually played through them has payed off. Do it, it's worth it, it's not obsessing.
Now, 2 days later I think of things I could have done differently and what I learned from the experience. There's so much more to learn and that's what makes this thing we call boating so interesting?!? Oh yeah, and the calls to get prices on a new shaft, haul-out, and the prop rebalanced. Never mind probably missing a weekend on the boat.
How hard is it to replace a cutlass bearing?
Be Safe!
well, at least it happened on the way back... didnt' ruin your vacation ! :-)
a bicycle helmet is nice to have so you can get under a boat in not so perfect conditions...
a large back up bilge pump (3700) is a must have, and with an everyday 2000 it will keep up with a 2" hole or at least buy you time to plug the hole
I've heard that having a couple of zincs on the shaft just ahead of the strut will prevent the shaf from falling off and possibly whacking the rudder in the process... one hole is bad, two is worst !
anchoring will keep the boat upwind/upwave even if the anchor doesn't hold, you can also deploy lines from port to starboard cleats to increase drag and keep the boat pointed.
cutlass bearing aren't expensive... you may want to check your rudder to make sure the impact dint' bent the post and also check the other coupling... if one failed, the other might be on the way too...
You should be proud of yourself and son. You both kept a cool head. Good post.
Good post. You stayed in control. Good job. Ditto on putting a shaft zinc in such a place to keep the shaft from sliding out.
Glad it worked out for you, something similiar happened to my doctor on his maiden voyage of his new to him used boat. The shaft came loose from the coupling and backed out of the stuffing box. It lodged against the rudder but he had a gusher of water comming into the boat. He was able to stuff it with some rags to slow down the water so the bilge pumps could keep up.
A scary scenerio for sure.
Sounds like you did all the right things. At the end of your post, you say you thought of all the things you could have done differently. Like what?
Interesting story told very succinctly! I could visualize the whole thing as you told it. Glad everything worked out so well. Some of the best prep we can do to be safe on the water is the "what if" brain exercise. It really does make you more prepared when something goes wrong!
Nice Job.. I'll keep thinking thru those same things. It's easier to prepare for an emergency in your head for the first time then to actually go thru it without ever having thought about it. Your preparation paid off. Glad we have boaters like you on the Bay....
Thanks for all the kind words.
Yes - glad it happened on our way home, not on the way out. And think of all the fuel saved with the tow. :-)
Bike helmet, good idea. Yes, the anchor was the next move if we lost all maneuverability even though we were in 90' of water. Good suggestion with the lines!
Well - I can personally confirm the zinc close to the shaft, failed in this case. Hard to say if it was due to our 17kts was too much force, or corrosion weakened it. I used to put the pair of zincs next to each other, but someone told me to separate them to avoid too much weight in one spot and cause vibration. Guess where they both will be next time I replace the zincs...
What would I have done different?
Asked my wife and sons girlfriend to step down off the bridge into the cockpit to lower the center of gravity. Loosened the davit straps on the dingy to make it quicker to deploy worse case.
Most importantly, in the back of my head for a while and on the top of my to-do list now: replace the aging bilge pumps with new. Just prior to our departure for the island I was cleaning the bilge and noticed the mid-ship pump was making noise and pumping just a little slower than normal when I tested it. I made a mental note to replace all the pumps this weekend after our return. While it worked fine in this situation, I should have replaced it then and there.
Install high water alarms. I do have bilge indicators on the bridge that light when any of the bilge pumps come on, but I want them as back-up and they are in-expensive.
I though of this the other night while sitting there and as Pascal so correctly pointed out, a strong back-up pump. So purchase a good pump attach a long hose, a long power cord and battery clips to reach my ship batteries, batteries to a boat alongside, or to provide assistance to a boat along side.
There are other things, but that's the major stuff.
Great post John, thanks. A few really good things there to keep in mind and maybe an emergency plan.
I agree that you did well. N ow I will be interesting to determine the cause of the problem. Did you catch a crap trap???
To my knowledge, I didn't hit or catch anything. Leaving for the boat in a few minutes for the weekend and will pull the coupling tomorrow morning, maybe that will tell. Boat is hauled Monday so I can pull the shaft, that may be telling as well. From discussion with a few folks, they suspect galvanic corrosion at the coupling and shaft. I will certainly post what I find.
by back up I meant a larger pump with float switch, installed a little higher so that it only comes in when the primary fails or fails to come on.
if you have 2000 primary plus a 3700 as a backup, you should have plenty of time to find and plug the leak...
i was wondering about the zinc handling the shock... i guess that answers it ! :-)
jrekemeyer,
Great job out there on the water. I like you comment about more to learn also. I'm sure your son will be reliving these adventures when he gets older with a big smile.
John,
We went into blk on sunday. One of my friends boats hit something in block island sound sheared one blade off his port prop and mangled the remaining blades. Local blk diver replaced both his props that came over on ferry. We never saw what he hit and NOTHING shot up after the hit.
Glad it all worked out... Blk's an awesome destination.
When I picked up my boat in Maine this past April one of the mechanics there pointed out that, in exttreme emergencies, the diesel engines can be used to remove large amounts of water from the engine room in fast order. I'm not exactly sure how it works yet - maybe someone here can shed some light....
Could be another option in the total arsenal of getting water out fo the engine room/bilge.
He is talking about using the raw water intake hose. Meaning seacock shut off and hose removed, or hack saw cut in an emergency. But then you would have to be right on top of the hose as not to burn up the impeller and add more problems.
Sure, you can use the engine to remove bilge water. Take the raw water intake hose off the seacock and stick it in the bilge, and run the engine. There are also "flushing" strainers that have a valve on the top where you can attach a second hose. Generally used for flushing the engine, but you can leave the flushing hose down in the bilge and just flip the valve over.
Of course, all of this only works if you're on the boat and have time to do it. A 3700 gpm backup bilge pump works when you're away, too. At least for a while.
