Handheld GPS recommendations
Prospective
I would like to have a backup GPS/Chartplotter for my boat. I have a built in Raymarine system so this would be stricly for back-up, armchair trip planning, maybe some geo-caching, etc. Don't want anything that is designed to be mounted as I would like to use on dink, other boats, at home, etc...
I have read a little about the Garmin Oregon 400c which sounds good. Looks like best price is in the low to mid $400 range on the net. Any other suggestions I should take a peak at.
I have the Garmin 76Cx. I purchased it as a backup for the boat, and used it mostly for the dinghy, exploring....
I have a Raymarine in the boat, and one time, it just crapped out. Thankfully I had the Garmin available. I have the same tracks/routes on the Garmin as I have on the Raymerine.
One of the things I like about the Garmin is I can sit back in the cockpit or cabin, and preplan a trip without being hunched over the Raymarine at the helm. Secondly, the routes/track lines on the Garmin are far easier for these eyes to see. (Wider and bolder)
As far as the Raymarine, for whatever reason, it just quit. A friend suggested shutting off all the power to the boat (AC and DC) and see if something would reset. It did, and apparently there's nothing wrong with it that I can tell. Still, glad that I had the handheld. It started out more as a novelty....
I have a Raymarine 435i onboard an it stopped working a few times two years ago while under way. I removed one of the dash panels and saw it had a glass fuse. I removed the fuse and used a nail file to remove any residual oxide from the fuse and terminals and put it back in the holder. That worked, but not for long. So, this spring, I cut the fuse out and replaced it with a water proof blade type fuse like the ones you have in your car and have not had a problem at all this season. So for what it's worth, you might want to check to see if you have a glass fuse as part of the circuit.
As a result of the GPS failure, I bought a Garmin eTrex Vista Cx as my backup and keep it onboard. I also keep a few backup batteries handy.
My boat is only a 2007 sold new this year. Not sure how to even get behind the dash, it has these funky screw heads with 2 holes in it. Besides, it's currently under warranty (and still working on the punch list) and the one time it failed, shutting off all power seemed to work. I've printed your post for future reference just in case:) Of course there's also the issue of me and a screwdriver, I'd probably end up frying something...
Prior to this season I posed the same question here and arrived at the Garmin Oregon 400c. Although I haven't had to use it in place of my E series, I have toyed around with it quite a bit and know it will do the job well if I had to rely on it. I can easily recommend it for your intended purpose. I just wish Raymarine had a similar product as it would be nice to be able to share routes between the units.
Additionally, if you have an iPhone, the Navionics app emulates the cartography you likely have on your plotter and is terrific for armchair planning, checking tides etc. I would not want to have to rely on it as a primary navigation tool, but it's a terrific additional resource IMO since you always have it with you anyway.
siera,
thanks. I am a blackberry storm guy. would love the navionics app to come up on the blackberry store but not yet. thanks for the thumbs up on the oregon.
GBCruising, Don't want to stray from the original thread but here's where the fuse is located for the GPS.
6 or 8 months ago I dropped my little Garmin eTrex Legend and broke the screen, so did quite a bit of surfing looking at features of new units. Colorado and Oregon are nice, but pricey and I don't think I need all the gee whiz stuff on them, so finally settled on the Garmin GPSmap60CSx. The thing is amazing. It'll lock on to a location Inside my travel trailer or in deep forest. With the included memory card I downloaded the entire west coast of British Columbia from Topo Canada - and a good portion of the interior - with plenty of room left over. Now it's got all of New Mexico and parts of CO, UT, AZ with plenty of room left over. Those of you who looked at my picture stories last summer saw several pictures of it in action. I recommend it highly.
Lar.
I have a Garmin Colorado 400c, it's great! Many features, user friendly.
