Hanging pictures
ctcruiser
Hey Guys this is a question my wife wanted me to ask on here. She is trying to hang a picture and has tried velcrow and the museum clay they all work at first but as soon as the boat gets a little warm the picture falls. The wall it self is coverd by a vinyl material we would rather not use anything that will make holes, Any Ideas?
I used industrial stength velcro to hang pictures in my bathroom and it worked great. I got it at work and it is the velcro that Easy-pass gives out to hang it on your windshield. I'm not sure where to buy it.
3M makes some removable adhesives for such a project. Wally Mart and Target carry them. I have them all over the boat holding up coats, towels, and some pretty heavy stuff. No issues.
Edit - A little more information. 3M calls them "Command Strips". Here's their website for the products:
http://solutions.3m.com/wps/portal/3M/en_US/Command/home/
3M also makes a double sided foam tape....works well....and easy to remove when you need to.
You have forgotten the first rule of boating: Nothing goes on the boat unless it serves two purposes.
Pictures? It's a boat for heaven's sake, not a friggin airplane... just tape charts to the bulkhead...
When I was MUCH younger pictures DID serve 2 purposes!!!!
unfortunately you can't turn the pages on those old pictures anymore.
Heavy duty velcro has worked for me to hang a clock and a thermometer. Attach it to both parts, then let it set overnight before hanging the object. This lets the adhesive cure. Be sure to clean the surfaces with alcohol before applying the velcro.
You can use as much velcro as needed.
Make sure there is no armor all or vinyl protectant on the vinyl
3M Command Velcro Strips. Don't how much weight they hold up, but are great for my purpose. I believe the instructions tell you to first wipe the surfaces with alcohol, before applying the stick ons.
