- May 25, 2003
- 11591
- 1,986
I'm having a problem shifting into gear.It goes in ok, but requires more force than I think it should.
The outdrive is a Mercruiser Alpha 1..
It was brand new 2 years ago....
When I push the neutral button I can push the throttle easily, but when I try to go into gear it seems to require more force than I think it should..It was hard to engage last year, but seems harder this year..There is a detent adjustment that I have tried to adjust, but makes no difference.
It looks like there is a shifter cable from the control to the engine and one from the engine to the outdrive..
How can I tell which one is sticking?
If it is the one that goes from the engine to the outdrive, does the outdrive have to be removed to change it??
I'm ready to splash, but need to get this fixed first...
