Hard water Spots
jim conroy
I will be buffing and waxing my blue hull this winter. For the past two years I have cleaned the hull of hard water spots before waxing with an unknown product that was given to me in a detergent bottle.
The guy I got it from is not around any more. It worked wonderfully, smelled a bit like CLR.
I worked it onto the hull and around the through hulls, then wiped it off with 409 or windex before I buffed and waxed. This stuff also removed the wax so its a strong product.
What do you all use?
Jim 2004 420 DA
Anything acidic. Start with vinegar. If that doesn't work try CLR or blue toilet bowl cleaner.
yes anything acidic but be careful of aluminum parts with the stronger stuff.
You might try dilute SaltAway ( mild sulfamic acid routinely used in flushing alum O/B's) or even perhaps Dawn detergent will work. Dilute vinegar wash does sound like it's worth a try.
to avoid the hard water spots from getting there, use a water softener for the wash down water. there are smaller dockside units available.
vinegar mixed with water. I also have a water softener that I use on the dock to wash down the boat, keeps the spots off the dark blue hull, and it makes the admiral happy for taking a shower on the boat.
When all else fails you can always use Muratic Acid. Muratic Acid is also good for cleaning barnacles off bronze props.
G
I just wish it was warm enough HERE to be buffing and waxing my boat
Thanks to all,
These spots are left over from the lake water splashing on the hull.
If I buff and wax with out removing them they leave swirls on the blue.
I have the water softner but not much you can do when you are running.
I'd hate to use muriatic acid on the hull, I like the basic vinegar and water idea.
I've heard of ducky.
The stuff I had before worked great, it took a bit of elbow grease to work out the rust stains and the discharge through hulls.
Bobalong, I'm in heated storage, pretty cold here in Wisconsin
As the boatyards do, muriatic acid. No need for full strength. 50% should work just fine. As always, rinse thoroughly.
I've used toilet bowl cleaner and it works great. I use the gel, not the spray, and apply it with a large sponge (wearing rubber gloves). Rinse off and my blue hull looks like new, ready for wax. I think the product I use is called The Works or something with "Works" in it.
Since you have softened water at the dock, why not give the blue hull a quick rinse everytime you return to your slip. That would get the lake water off of the hull before it dries. Think preventing instead of fixing the problem.
The "Works" toilet bowl cleaner. It does a great job, even on south florida river stains. Use full strength, wear rubber gloves and don't get in on your trailer or other aluminum.
How long are you guys leaving the "Works" on before you rinse it off?
I don't let it set too long. I sponge it on a section, let it foam, then I go back over it with the sponge and then rinse thoroughly. I assume the foaming is the action that takes care of the spots. FYI, it does leave streaks on the bottom paint so use it before you paint the bottom. I don't paint the enire bottom every year but I do have to touch up above the water line to get rid of the streaks.
if you want to try a milder acid than muriatic or toilet bowl cleaner, use FSR. its a blue gel sold in most marine stores. its phosphoric acid and it won't hurt anything, but it will remove any wax that you have applied.
Vic,
FSR? What I had was blue and perhaps not a gel but a thick liquid.
Where I'm stored there is no way to 'flush' any acid off.
I'd need something I can remove with towels.
Removing the wax is fine, I'm going to re-wax anyway.
