Has anyone tried this?
mrdeepseafisher
I bought several tubes of 5200 from Boatfix a few weeks ago and used it last week. If one were to read the side panel it clearly states that once opened it will cure in 24-48 hrs. It does.
I am working little by little at night after work and can't use the entire tube. Has anyone tried using one of those home vacuum sealers to reseal the tube until the next time its needed. I thought this might prevent the moisture from curing the product.
Comments welcome.
Never tried a vacuum sealer, but a close-fitting airtight enclosure works ( not well, but it does work ).
The best thing for keeping an open 5200, Boatlife or Sikaflex tube fresh: leave it with the plastic nozzle on and filled with a small glop of the sealant exposed at the end. That usually keep it usable for another couple of weeks, sometimes for months. Twist the nozzle off and you should have uncured sealant. I never throw the screw-on nozzles away, but pull out the cured sealant and re-use them. These sealants cure with water vapor.
Even better is a hardware store item called Little Red Cap. Put one of these tiny condoms on the nozzle and fill any voids with sealant. Buy extras for pranking purposes.
I now buy 5200 in the small squeeze tubes. Costs a little more but i don't waste as much.
Life-Caulk is my favorite.
Little Red Cap fits all caulking nozzles: caulking gun tubes and the handy toothpaste tubes (which come with a cap: the best solution).
I've kept opened tubes of 5200 in the freezer for months. Just have to let it warm up to room temperature before you try to use it. You may have to clean out the tip some.
I just bought a tube think i will try the freezer thing only need a liitle bit.Thanks
I have a tube of 4200 from the summer. I was going to use it to put in a new Garboard. I thought it seamed plyable when I looked at it. Does the stuff harden and become unusable, or are you just now supposed to use it after it has been opened and resealed for a bit?
If the sealant or adhesive flows and smells like new then go ahead and use it. If it is starting to thicken up then it is partially cured and shouldn't be trusted. I've used 5200, Life-Caulk, Sikaflex, etc. that was opened and then stored for a year or two and they worked just fine. Then sometimes they were completely cured and hard so I just tossed them away. The more that is left in the tube, the more likely it will store well. I had one caulk tube of Sikaflex that was opened, used and stored for about two years. The top half of the tube was cured and hard, the lower half was still good. I put a hole in the lower half of the tube and squeezed the good stuff into a hypo and used that. Sure beats another trip from the boat to the store.
yzer, what does fresh sealant or adhesive smell like when new ???
The sealants all contain volatiles of one kind or another to help them cure. When you can't get that chemical whiff then you know they're too old. The silicon sealants all contain formic acid that smells like vinegar.
Incidentally, ants use formic acid to mark their trails. We have a lot of native ants in my part of the county. If you use silicon sealant to caulk a bathtub or shower enclosure ants will eat it as long as it releases the acid and you can say goodbye to your caulking job. I just use poly sealant if the ants are around.
mrdeepfisher,
Destin2 got it right.Works like a charm!
Cardy
I haven't tried this, I just read it somewhere on the web. Use a wax toilet seal ring (preferably unused.) The idea was to just stick the end of the tube into the ring upside down, and all your partly used tubes are in one place. On the boat you might just stick a wad of the wax in the end of the tube, easier to stow that way.
FYI The sealed caulking in a bag seems to work well. I just slit the bag open and used a little this morning. It was just like opening the tube new,same strong smell.
One problem however, looks like I will be purchasing a new vacuum sealer for my wife. She got a wiff of the smell and is convinced I have ruined the sealer so that it can no longer be used for food.
I will try the freezer trick (sounds good)but I am a bit worried I will end up buying a freezer next.
