Hatch gasket recommendations?
Prospective
My engine hatches raise up from the cockpit sole on actuators. There is also a day hatch in between. The gaskets are all of different vintage/condition. And they don't do a very good job of keeping water out.
Any suggestion on a brand of gasket. I would like something rubber, not foam that I could "peel and stick". Only thing I've been able to find is bomar hatch gasket that runs about $6/ft. Seems steep and not sure if it's the right thing. Wondering if there's something else???
??I presume the hatches are made by Tiara. These are not port hatches but rather engine room access hatches.
I see, there is a website that has zilions of different gasket patterns. Try searching for gaskets and or seals
You can buy the original gasket directly from Tiara, which I did. But it is pricey.
The hard part will be installing it under that raised deck.
