Solved thanks to Jason at Hurst Marine. Small sensor on transom door/boat frame recess. Taped a dime to wall covering sensor and power was restored to hatch lift. Ordering new sensor but the trick did the job. The wall sensor just wore down enough to prevent contact with the metallic button on door.
For future reference......Can only speak to the 330 lift, but I have found that rubbing the rag of checked oil on the shaft prevents binding. I don't know if that makes a difference in your situation, but I hope it may help.
