HawkSpeed from Sea Hawk
Edgar
Anyone with hand-on experienced or know of someone who have used it. Its been around for a couple of years now and dont know if its worth it. I did used propspeed many years ago and it work for me, but to expensive....
I used prop speed last year and was very unhappy with it. The cost is prohibitive and not worth it in my book. This yr. I used hawk speed for about half the price. We shall see which does a better job.
A friend of min sells it and says it works great. It is to compete directly with propspeed. If it doesnt work any better I figure I have saved quite a bit of money.
Tried it. Not happy with it. Stick with Prop Speed. Never had a problem with it.
I found HawkSpeed to be less expensive online than PropSpeed.
Importantly, HawkSpeed is easier to apply as it has a 30 min window between the etch coat and the topcoat. PropSpeed requires the topcoat immediately applied over the etch coat, hence they recommend 2 people for the application.
Just launched so have to evaluate HawkSpeed in the fall.
Ronbo
Have used prop speed in the past,was very pleased with its performance over a two year span. It is expensive. Am using prop Koate right now,so far it is working, less expensive,but perhaps not as effective as prop speed.
Several users of prop speed here are pleased and are staying with it.
I use PropSpeed and yes it is pricey but the cost of the material is a very small portion of the overall project and mine works for two years in a high marine growth area.
PropSpeed is a very slick 2-part coating that can be applied to any underwater bare metals (nothing painted). When the product dries for about 24 hours before launching it feels very smooth and is an odd mustard yellow color. It works by not allowing any marine growth the cling to the surface. Any material that does start growing on the PropSpeed will be slung off once the vessel starts moving. I have had more success with the props and shafts than the trim tabs or thru-hulls. The more the part moves the better.
Ronbo
Prepare to be disappointed.
