HDTV Antennae recommendations
foggysail
Last year I thought I would install a satellite dish for times away from the slip where I have one mounted on a piling. Was a bad year for me with probate expenses so a tracking dish is out for this season. But HDTV is sooooo sharp maybe I can get away from worrying about another major installation job on the boat with a simple antenna.
What are others using and are you happy with the antenna performance? What price range is the antenna in? Is it worth purchasing something that can tune to different azimuths? Yes, the season is almost behind us here in Massachusetts although we plan to use the boat on trips through September at least.
Foggy
If you are talking about HDTV from the local broadcast stations, you do not need a special antenna. Any antenna that works for standard TV now will work for HDTV broadcasts. I get 28 HDTV stations on the boat on a standard TV and a $40.99 digital converter with rabbit ears. If you want real broadcast HDTV then buy the HDTV and again, keep your old antenna.
If you are talking HD TV from satellite services, then you need the new HD dish, HD receiver and HD service package.
I just installed a Magnavox converter for my anaolg tvs on the boat. Works with my existing Glomex antenna. Crystal clear picture with about 20 english stations. Hardest part was mounting it in the entertainment center.
I use a Glomex with the preamp and a 23" Jensen HDTV ready 12 volt TV and it works great. But I still prefer my KVH tracking antenna and the satellite.
Yes, I would prefer satellite also. We recently purchased a new Sony HDTV that eliminates the need for a converter. I have not gotten around to checking the new HD operating frequencies but from the responses, looks like a regular old TV antenna will work.
Foggy
I'm pretty sure HD signals are all on UHF band, which is why there is no need to change antennas. Foggy, don't forget there are less expensive satellite options. There's Follow-Me and (my favorite) AzTrax, each under $1,000.
I also think I heard the VHF band might eventually end up getting auctioned off, which would mean some fantastic building penetration for whoever purchases it....wireless phone companies perhaps?...Bill, we'll hope you've sold off the business and gone cruising by the time that happens :-)
The HD TV channel allocation plan is a bit twisted. Right now most VHF stations run their HD channels on UHF, but there are a few that run HD anywhere on the VHF spectrum.
Things will change in February 2009. As you know, all standard TV broadcasts will cease at that time. In addition, no stations will broadcast above UHF channel 51 after that date and many stations that operate standard TV on VHF with HD channels on UHF will switch their HD channels down to the old VHF channels.
So, in February expect to see standard analog broadcasts end and a lot of the current HD channels on UHF moving to VHF.
Any good UHF/VHF TV antenna with a 50-ohm 75 ohm coax transmission line should work just fine for HD broadcasts today and in the foreseeable future.
Not sure where the 50 ohm comes into play. TV's typically have a 75 ohm input, coax input. Most antenna's are 300 ohm. They probably have the 300 ohm to 75 ohm impedance adapter built in. 50 ohm is more related to radio.
My bad, mandm1200. I'm kind of a 50 ohm radio guy. 75 ohm coax (RG-59) is correct for the VHF/UHF TV connections. 75 ohm RG-6 for broadband cable and satellite connection.
Originally posted by yzer
....... As you know, all standard TV broadcasts will cease at that time........
That is not quite true. If you are in an area that receives OTA television via a translator station, those can remain analog. Low power TV stations can remain on analog also (but who cares about those :))
It is assumed that translators and LPTV will transition to digital in the future, but no date has been set.
The analog-to-digital licensing process mandated by the FCC suggested that analog stations could apply for a combination of digital frequency (channel), antenna height and effective radiated power that would result in their digital signal having approximately the same coverage area as their former analog channel. Some former UHF stations (channels 14-83) opted to apply for a license in the VHF band (channels 2-13) and many former VHF stations chose to move up into the UHF spectrum. Across the country, there are currently digital TV stations licensed to operate on virtually every channel from 2 through 68. I haven't seen one licensed to operate on channel 69, but there may be one, although I doubt it. This transition has been going on for years and has cost the broadcast industry billions.
Don't forget about the $40 rebate cards from uncle sam. Mine came in yesterday's mail. Heading to radio shack this week to get the converter box. Mrs. Robinson put his in a couple of weeks ago and says it works great.
I bought one of the digital converter boxes and installed it over the weekend. I started to receive 5 channels 100% clear so I was thrilled. I turned the boat around and could not get anything! Checked all connections to make sure nothing came loose. Still could not get anything, moved the antenna (mine is not permanently mounted yet) back to the side of the boat it was on. Nothing! Brought the TV, converter box and antenna home with me and it received 11 channels. Anybody have any ideas?
I bought the Artec T3A Pro, works on 12 v DC and I'm using my original Shakesphere amplified antenna on my arch. Getting 31 channels crystal clear.
Where did you get the Artec T3A Pro?
Gee, I neglected to check how this thread was doing, it was doing just fine.
Here is a discription of my current status. We have Dish satellite at the dock along with a new Sony TV in the boat. We don't need a converter box. I did want to add a satellite dish on the boat for times away from the slip but I had a financial catastrophe involving a family probate problem this year so no roving dish for the season. However I did install a 1KW 24vdc (two group 29's in series) Xantrex inverter/charger so we can get locals whenever the boat happens to be away from the slip. I limited the inverter to only a killowatt with the thought if higher power was needed, I would use the generator. Besides, the season is half over for us here in New England.
Back to HDTV---- I did look at the frequency spectrum and I thought most stuff would be going to UHF but that is still not clear. Also I have considered purchasing a Winegard SquareShooter and mount it under the canvas so I can manually point it rather than on top of the radar arch which is unaccessible. OK, thats about where I am. We do get a couple of channels with rabbit ears but..... reception is unreliable.
Foggy
Question? The videos show the converter between the input and the TV. Is this a requirement? Saint Max has one input on the port side (outboard) and two TV connections in the cabin. I would like to use the box outside (or inside if I can figure out the wiring) and use the two TV's independently with their own remotes. Is this possible or do I need one box for each TV.
As little as I watch TV, this is also a question for my home as well.
You need one converter for each television. The converter can only tune one channel at a time.
