The headliner in the cuddy cabin is sagging about 4 to 6 inches. Is there a good product to re glue headliner and not have to mess with this again? Screws will not work because of limited deck thickness.
I've had that problem too. I tried all the spray adhesives I could find and finally just copied what the manufacturer started doing the model year after our boat was made (figures). I added more wood to solve the problem:
The screws I used just barely go into the fiberglass beyond the wood. I only drilled pilot holes in the trip and let the screw tap itself into the glass. But to be honest, that deck is a good 1.5 or so inches thick so I wasn't too worried.
