Help, I am having withdraw ....
nph
I had to pull the boat yesterday (Regal 277XL) - the port outdrive is not shifting correctly. When you shift, you have to pass, the detent on the throttle to get it to go in gear. The mechanic was down last week and adjusted the upper cable, and it got much better but not right.
He suggested pulling the boat, and checking the lower cable. He is 75% sure it is the cable not the drive. We (mechanic & I) pulled the boat yesterday, and I am already going into withdraw. I am afraid he will not have it done and back in today.
When we pulled it, he said if it is the cable, it should be done today.
He said I should hear from him around lunch time. What a way to make the day drag out!!!!
Please realize I am being very sarcastic, I could not ask for better service. Last year, two days before my cruise vacation, the upper half of my outdrive failed, Pulled the boat Monday AM, and he had me back in the water Tuesday PM.
I feel your pain. I went to run my motors and complete my spring maintenance items and when I dropped the port outdrive down, oil came out of the center of the prop. So I have a seal leak somewhere in the drive. I have an appointment May 30th to drop the boat off. So it looks like I won't be boating for a few weeks yet.
I just received my new lower gear housing for my B-III and cant wait to get it installed. Havent had the boat on the water since last June...
Just got off the phone with the mechanic!!! Life is not fair. Good News/Bad news The good news (I think) was the cable is fine, but while he has it out, he is going to replace the lower cable, He mines well, it is going to take until next Thursday for the new lower unit to come in. (That's the bad news)
He said the upper half looks fine, but I am going to replace it at the same time. The cost of the uppper is not that much, why mess around. He is also replacing the gimbal bearing and well as the bellows. I was planing on having that done in the fall, it just moves the spending up a little bit.
The sad part is I could of replaced the outdrive if I knew it was going. Less then 2 hours on it this season!!!
Winters Remedy, I swore I would go from outboards to Inboards, because of I/O horror stories I had heard. Then I listen to my friends with inboards, the stories are just as expensive. This one has a cutlas bearing go bad, that one has a bent strut. Now I just take it all in stride. It is a boat, it is going to cast you money.
As a good friend of mine says, if it Fly's Floats or F...s it is going to cost you.
I also feel your pain ... went to launch the boat last month ... started right up ... began making an expensive noise .... long story short ... 1 month and many $$$$ later I should be in the water next week. More details later!!
You should all feel good that you are stimulating the economy!
Going for a shakedown cruise tomorrow....
Can I come over on Sunday and park my little Annabo in your slip for the day? maybe I'll even take you out for a ride. :)
nph I agree it's a boat and all have their problems, I'm just sick of the maintenance on the IO's after 8 years so I'll give the inboards a shot. Good Luck.
I know how you feel I upgraded last year but then down side is having to watch the tides to go in and out. Other then that happy as a clam. How is it going with the sale?
Put her on a lift and reduce the costs! I rarely have more then standard maintenance on my I/O since I bought the air dock.
Audrey II it's going, not as fast as I would like but you know how marina's move. I'm just going to start using my boat until things are ready, what are you going to do, I've been doing alot of home projects and the weather is really not been great anyway.
Bob, I wish I had seen you offer before today. I might have taken you up on it!
Over all not a bad weekend, to have the boat out of the water. Saturday, went to to other yacht clubs, someone else was nice enough to take thier boat, and Sunday the weather was only so-so.
My daughter has been saying she wanted a weekend at home to hang out with her friends, so I got that out of the way.
The drive was ordered and FEDEX has scheduled for delivery for Tuesday. Knowing my mechanic, it will be ready to launch again Tuesday or Wednesday.
Flutterby,
One always has to look at the bright side of things! The real bright side of this, is I just checked the FEDEX site, and the drive is out for local delivery. When I spoke to my mechanic lst night and told him, it was on time for todays delivery, he said if it is there early enough, he will have it done this afternoon. What a bummer, I am working 5am-10pm today.
Looks like I will be the water for lunch tommorrow!!!
Thank God, my withdrawl is over. Splashed the boat today.
That is what I call fast turn around. Pulled the boat last Thursday night, had it apart and diagnosed by 2pm Friday. I ordered the outdrive and it was delivered to the mechanic at 12:30 yesterday, by 5:30pm he called and said the boat was done!!! Got to love a great timely mechanic.
Bob you coming north on the river this weekend?
Wow, that's awesome service!
Don't know if we're gonna get out this weekend, it's pretty crazy with birthdays and picnics and stuff. If I do, I'll stop in and look for you. Send me a phone number to blouderback at yahoo.com and I'll reciprocate.
All that $$$ for a shift problem, Je**us! I've never owned an outdrive and now I think I know why! I HAVE pulled rudder, prop, shaft, cutless, even the engine with the boat IN the water; haul out for a simple shift issue, unthinkable!
Willie,
How do you pull a shaft with the boat in the water? same thing with the rudder, I thought if you pulled the shat, you ended up with a 2" hole in the bottom of the boat? As far as cost goes, I do not think either one is any cheaper then the other, they both cost money! It all depends on what needs to be done. What does it cost to repace a bent shaft?
Very carefully!
Yes I had a hole in the bottom of the boat (two actually), but that's what plugs and bilge pumps are for! Believe it or not a boat will NOT sink in 2 minutes with a shaft or rudder out, it takes a while. Once the plugs are in even a small pump can handle the water.
Really it wasn't all that different from doing it OUT of the water. You just have to plug the holes.
My shaft is only 1-1/4" in diameter and a little over 4' long so it wasn't all that heavy or hard to handle. Where I dock my boat the water is usually about 4' deep so I can stand on the bottom while I work. I also have a shallow draft boat so it's not that far under water I didn't need any diving gear. The hardest part was getting the not-too-clean shaft through the cutless. I'd scrape what I could reach, slide it back a few inches, scrape some more, etc.
My only cost was the new shaft. This was several years ago and I don't remember what it was, but it was probably less than what the yard bill alone would have been.
If I had to do it again I'd probably haul out, I'm not as young (or as cheap) as I once was.
