Help Locating Part { Plexi-glass}
36mainship36
Does anyone know where to get the dividers that are used on the bridge venturi plexi-glass wind shields. They are used to join two or more sections on the bridge. Any help in this matter would be greatly appreciated
Lou R.
sounds like you mean the aluminum extrusions. if so try Taylor made products inc
Bruce, my connectors are made of plastic. They connect two seperate sections of wind shield. I will try Taylor.
Lou R.
Try Marine Connection Liquidators in Ft Pierce, Fl. They buy builders surplus and have just about everything.
Or take an example to Tap Plastics. They can make just about anything plastic........
Lou, with Silverton, we have a great service available in parts available for older models sold to the public from the manufacturer. Since Mainship is the same parent Co., maybe they have the same thing. Try calling Mainship.
Contact your boat manufacturer and find out if you could purchase OEM parts directly from them or one of their dealers.
They might also tell you who they purchased the parts from originally. You could then purchase an exact match to your existing "H" channels.
