Help On Nomenclature
gcolton
Well-known member
I have no clue what the item I am looking for is called.
It's function is to allow a boat to ride up and down a piling(s) as the tide changes. The device is bolted to a piling and the boat is tied to a traveling fixture. The fixture travels up and down the a track and compensates for tidal changes.
I have seen these things advertised somewhere but do not know how to search without some better description/nomenclature.
I know my description is shaky, but can anybody help?
George
The item you refer to is called "tide slide". They advertise in several boating magazines.
Another is Slide Moor.
Pricey little devils that could probably be home brewed for 1/10 the cost.
Thanks. That was what I was thinking of. Just could not come up with the right words.
I am moving out of my nice wide slip at a local marina and into a narrower slip at the base. I would feel more comfortable with something come hurricane time. The Tide Slide seems the best to me.
The only problem I see is how does the boat next to me tie to the same piling. I have e-mailed Tide Slide to see what they suggest. I would probable use one on each side tied to my mid clean and one spring line.
The pilings in the aft are not tall enough to be worthwhile spending the money so would tie off to them conventionally. Have to work it there so I have somewhat long lines to provide for tide rise. Of course I would be retying as long as I could get on base.
George
There are other ways of allowing the line to ride up and down. You can cut pieces of PVC pipe into 2" lengths and string them either over a loop of line, but better a loop of chain or cable, and shakle the mooring line to the boat. With two boats you could have two loops with the PVC "rollers" on the same piling. Of course during hurricanes you do want to have very long lines, such as spring lines--and we often put these on pilings some distance away--such as the other side of the dock, to allow more lattitude of rise and fall of the surge.
This boat used tide slides in a Hurricane with only 11' of tide change:
Unfortunately those were rather short pilings. Too bad they were not able to get more travel. Where I will be I would not be able to handle 11 foot either. Luckily we have no history of that much in this area either.
G
Look into "hurricane hoops" and Tide minders. I have the tide minders but I had a stainless steel cable made so now they are just like the hoops for less money.
Cor
G, the only travel that boat owner needed was to go north about 5 miles and anchor in a borrow pit. Do yourself a favor, don't spend alot of money on gizmo's for hurricane protection. Find yourself a good hurricane hole and spend that money on six or eight, 600' spools of 1" nylon line. Splice thimbles in the ends and use chain to secure yourself to hard objects. Ask the locals about Opal.
I am the locals. I have lived here 31 years.
Personally I have no interest in the so called hurricane holes around here. I have seen too many boats who were properly secured being wrecked by other boats that were not properly secured.
By the way, there is no water 5 miles north. That is all Eglin AFB reservation.
G
If you are local, you know that boats in a marina in narrow slips get eaten by the piling during hurricanes. You also know about the GICWW, east of the bay where the high bluffs are (North of Grayton Beach area). You also know that during hurricane Opal there were many Millions of dollars worth of yachts destroyed in the Destin/Ft. Walton area alone. Being a local you also should know that not one of the many Charter Boats from Destin Harbor suffered any damage from Opal. They all left their slips and went east to the GICWW.
If you would like to travel 40 miles east (or whatever direction you choose) and leave your family while you ride out a storm, please be my guest. Yes, that high banked area of the IntraCoastal would be good for riding out a storm. (Incidentally it is several miles east of Grayton Beach.) I is also very narrow so little maneuvering room. If many non-commercial boats decided they were also going to join the fishing boats there, then it would probably get to be a circus.
There were many boats washed up on shore after Opal. These were mostly boats that had been anchored out and not properly anchored to weather the conditions. There were also some boats in marinas that sustained damage. However, there were also many other boats in marinas that had been better prepared and did not sustain damage. Much depended upon where the marina was located. Shalimar Yacht had a good record. Those on the sound did not fare well. Bluewater bay did well.
I will prepare my boat as well as I can to ride out a storm in her slip. I will not put her in a slip where I think there is no chance. This is why I changed marinas last spring. However, when it comes time to take care of my family or my boat there is obviously no choice.
G
I don't see the tide slides in the picture. I see a lot of lines as in the "before tide slides" diagram in the ad though.
Dave, get out your reading glasses, look for the vertical bars on the piles. In the last photo look just to port of the fly bridge steps from what's left of the aft deck, just above where a shore power connection is laying down. You want a total loss, leave your boat in a marina slip!
Thuddie will tell ya how in the old days folks dropped a tire over the pole and tied to that. It floats and provides a lot of spring.
