We are lucky enough to own a 88 Silverton 34X that we use on Great Sacandaga Lake in NY. We need some advice on anchoring. The bottom is a mix of sand, silt, muck, etc. We have a Danforth #13s (that is what the survey says) with 2' of 3/8" chain on 5/8 rode attached to a Windlass c-3567. There is a #8 for a rear/spare anchor. I find it very difficult to get a good set with the #13s anchor and wondered what should be done. I thought of adding more chain, but the Windlass can't handle it so I would have to wrap it around a cleat or two. I thought about adding some lbs to the anchor shaft - like scuba dive belt weights, but that might not work with the clearance/width of the pulpit slot.
What does everyone think would be best?
Is there a better type of anchor I should look for in these conditions?
TIA
TIA
