I'd venture most likely case would be bad or wrong sender ( sender wire otherwise grounding out). Could it have been erroneously replaced with a dual-station sender since last working properly? Check with a mechanical gauge in the sender hole or just try a new sender that matches your presumably single-station gauge setup and Std (US) or Metric (Euro) ohms range( whichever your particular auges are.).
remove the sender, pull the coil wire and crank the engine for a few seconds with something in place to catch the oil spill, clean out the sender with mineral spirits and reinstall. see if that works.
I hate to say it, but smack the gauge with the palm of you hand when its high. after doing that my mechanical rpm gauge matches my smartcraft digital reading.
The first thing to do is verify if the high oil pressure is really high. Borrow or buy a mechanical gauge. I am not familiar with oil pumps for boats, but if like an automotive pump there is a pressure valve that will open if the pressure exceeds a certain point. That valve could be stuck in the closed position. At idle the engine will not make as much pressure as it does as the rpms increase. A cold engine will also make more oil pressure as the oil is thicker than it is once it comes up to temperature.
