I am looking into replacing my 40 gallon black water holding tank and have noticed two different fitting configurations. On some, like the Sealand, the discharge hose is attached to a fitting on top of the tank which is then attached to a tube going to the bottom of the tank. To empty the tank, the contents are pumped up the tube and out. Another design has a fitting for the discharge hose on the lower part of one end of the tank and the contents are just pumped out the bottom of the tank.
My current setup is with the fitting on the lower end of the tank. I have room to install either style. I can see a few advantages to each design. Any thoughts on which is the better configuration?
Thanks.
Thanks.
