capecodmoon
- Aug 5, 2008
- 30506
- 14
My boat is a 30 year old Chesapeake Bay Work Boat which has always been a "cruiser." There has been no re-design of the head/ holding tank area but the standard head (raw water in, black water to a holding tank), the white hose and the holding tank have been replaced(Head=2 years by me, hose=2-5 years and tank=5-7 years). The smell is almost overwhelming at times so I have cleaned at various times with a strong green cleaner, a bleach solution(not mixed with any other cleaner) and general cleaning. There is usually a short period (2-3 weeks) that is fine but it reverts back to its former smell.
There is alot of white hose with some sharp curves and while I believe that I have very carefully checked the hoses and the clamps and because it is such a small area and so difficult to get to, I probably have not done a good job.
While I do not look forward to it, the only solution I can see is to take it all apart and re-design and start over. Any input would be helpful. The holding tank is now 25 gallons so I am wondering if that might be overkill. Presently, I do not go on long trips so what would be a good size for local trips and not much use of the head? Also, the re-design means cutting/ripping up a great deal of the area where it is located. It is not a problem if the re-design looks as if it would truly work. Thanks in advance for any and all thoughts and references.
